Non planar roof surface from grasshopper to revit
What is the best way to add non planar roof surface to revit as a native roof family. I think the only way is to use roof by face mass in revit but i when i add these surface to revit through add direct shape component,
revit does not seem to read it as a mass.
Have you used Mass Family Template or you just used Add directShape Component?
You Can use Host Shape Component
My roof boundary curve is not planar, so this method does not work.
@Panudhon_Luechapanic Can you share the grasshopper files where you have defined the roof profile.
