Non continuous Moment on simple diagrid roof
Hello all,
Im having trouble understanding why the bending moment isnt continuous at the top of the columns which are suposed to be fixed like the other curve intersections from the model.
Especially when I dont consider columns and the fixed supports are directly on the grid structure, the continuity is not verified.
Can anybody explain if this is normal or not ?
Test File.gh (34.8 KB)
Thank you !
Hi, your supports have the rotational degrees of freedom fixed. Therefore, the supports can develop reaction moments, and the bending moment diagram does not need to be continuous between the connected beam elements. If you release the rotational restraint at the supports, you will see continuous bending moments.
