Non closed surfaces
hii,
Im triying to do closed surface model with curves and angles. I used patch, loft and sweep2 for the side surfaces however ı could not make it could anyone help me please.
you can see that the surfaces did not match thank you.
the side surfaces joining the body however the model not seems to be closed.non closed surface.3dm (187.5 KB)
Hi @user246
It could be a multitude of different issues. The best you can do is to export the curves and surfaces you have so far to a new Rhino file (export selected), post it here and I’m sure someone will take a look!
HTH, Jakob
Hello - make the side surfaces with say a Sweep2 or loft of the two long curves
Patch is generally a poor first choice for a primary surface, especially one that has four clear edges. Please see
http://docs.mcneel.com/rhino/6/training-level2/en-us/Default.htm#topics/03_nurbs%20topology.htm%3FTocPath%3D_____6
