Node in Code - Group Points by distance
Hi there,
I am trying to use the “Group Points by distance” command with ghpython.
The ghcomp.PointGroups manages to order the list of points I am feeding it, however it does not create sub-lists (branches) for each group.
In the image below, the panel on the left is from the ghcomp script, while on the right it is using standard gh components. I would like to do this within ghpython if possible. As the image displays, the script is working well, however I need to have nested lists in order to make any use of the command.
Any advice would be greatly appreciated!
Hi there,
I got exactly the same issue…
If this could be fixed it would be great!
Thanks,
Paul
This is fixed in WIP. You need to call the _tree version:
Thanks Marcus!
Looks like the same problem surfaced in Rhino7! This time, the module ‘ghpythonlib’ does not have the attribute ‘PointGroups_tree’. Help?!
Same here, I tried to call PointGroups() from Rhino Python but couldn’t get correct result. And PointGroups_tree is not avaliable in Rhino 7 or 8.
Finally I figured out the solution:
Snipaste_2024-03-22_20-58-43
