Nobody needs PlaceHole command because MakeHole does the same thing and it has more options.
Well, not exactly, PlaceHole allows you to use a closed profile oriented any way and place it on a surface oriented differently from the profile. MakeHole only works with objects that intersect the projection direction of the chosen profile. I agree that I personally don’t use PlaceHole much if at all, bit others might…
Note:
@rajaa, serious crash bug discovered if you choose a non-planar closed profile - in both V5 and WIP. Be careful testing… https://mcneel.myjetbrains.com/youtrack/issue/RH-37889
–Mitch
I see it, and I’m on it. Thanks.
Update: Fix is checked in. You should see it in the next WIP
