No surface objects to export (to STL)
When I try to export block instances to STL, then I get:
No surface objects to export.
I can work around this with ExplodeBlock, then export, and then Undo, but that’s not a nice solution.
Background: I am preparing an STL file for printing by Shapeways, and I have a lot of small objects that repeat. That’s why I made use of blocks.
Hi Felix- my quick test seems to work OK- I made a box, Blocked the box and successfully exported it to stl. Can you post or send me an example that does not work, via tech@mcneel.com?
thanks,
Thanks for checking, Pascal!
I am using an old 90 days evaluation version of Rhino 5. Possibly it was a bug back then, that has since been fixed.
(As said before, a rental version of Rhino would be great for us hobbyists, that cannot afford a full version.)
