Using V7 WIP, latest release. When I right click in the material panel, normally a pop up sub menu appears, it is not popping up when I click on a material and right click ?
I believe that popup menu is for Panel : Materials
. You are looking in Properties: Material
Hmm, but if it did work in v6 then I think this is a regression. I haven’t used v6 in a while, so I probably forget
I’ll log it for @maxsoder : https://mcneel.myjetbrains.com/youtrack/issue/RH-60759
Hmm, I’ll leave it to @maxsoder to further comment, but in my further testing in WIP: context menu works when you have an actual material selected, but not in that dropdown menu of materials.
So I guess it is about the popup menu when right-clicking on a material in that dropdown box.
… and will be available with the next BETA build
