No response when click export IFC
Hi, I’ve update the licences. However, it is just no response when click export IFC.
And no remind word in the commend line.
I need to check this menu.
The best way to export IFC directly from Rhino is to set up a layer hierarchy as outlined here
Using Rhino IFC Layers - Geometry Gym
You can then right click on the layer node classified as IfcProject, and there is a context menu with export there. Does this make sense and work?
Hi, here is the screenshot.
When click the IFC export, just no windows activated.
