david.adam
(David Adam)
September 2, 2021, 1:02pm
1
Hi everyone,
I am working with a Dell Precision M6600. Sometimes when I start Rhino it freezes after the first click. This happens when I run Rhino on the Nvidia Quadro 3000M or the integrated Intel Grafics.
After a while, this error appears:
Then Rhino stops working. I have to restart the laptop to be able to start Rhino again. But sometimes, this problem doesn´t appear and Rhino works well. What could be the problem here?
DanBayn
September 2, 2021, 1:08pm
2
Are your graphics drivers up to date?
david.adam
(David Adam)
September 2, 2021, 1:12pm
3
I´ve got the latest drivers, but they are not really up-to-date. The Intel Grafics driver is from 2016, the Nvidia driver from 2018. There are no newer drivers. I´m working with a quite old workstation, maybe that´s the problem…
Run the Rhino command SystemInfo and post the results here if you are using Rhino 6 or Rhino 7.
david.adam
(David Adam)
September 2, 2021, 1:17pm
5
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Studentenlizenz, build 2021-08-10
License details: Cloud Zoo. In use by: David ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 12Gb)
Machine name: DAVID-PC
Primary display: Intel(R) HD Graphics 3000 (Intel) Memory: 2GB, Driver date: 5-19-2016 (M-D-Y).
> Integrated graphics device with 2 adapter port(s)
Primary OpenGL: NVIDIA Quadro 3000M (NVidia) Memory: 2GB, Driver date: 1-13-2018 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 377.83
> Integrated acclerated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 1-13-2018
Driver Version: 21.21.13.7783
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Users\David\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino6.Plugin” 0.0.21124.1031
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.35.21222.17001
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
david.adam:
There may be new drivers available if you are basing “There are no newer drivers” on what Windows reports. Check on the Intel and NVIDIA driver websites (not third party websites) to see if new drivers are available.
Method for updating drivers: Updating Intel HD Driver
Added: It looks like @david.adam has the latest driver for his NVIDIA graphics.
Does the problem occur only when opening and working with particular files?
Did Rhino 6 work properly previously and only started having problems recently.
david.adam
(David Adam)
September 2, 2021, 1:40pm
8
The problem occurs only with one big file (and sometimes I can even work with this file). Otherwise, Rhino works well and worked well previously.
pascal
(Pascal Golay)
September 2, 2021, 2:42pm
9
Hi David - see if it helps at all to slide this slider left:
david.adam
(David Adam)
September 2, 2021, 2:59pm
10
Strange enough there is no such slider.
pascal
(Pascal Golay)
September 2, 2021, 3:00pm
11
Ah - sorry, my bad - I thought this was V7, I see it is not. Can you uncheck the ‘gpu tessellation’ box and see if that does anything?
david.adam
(David Adam)
September 2, 2021, 3:08pm
12
Right, I´m using V6. With GPU Tesselation unchecked, it seems to work but I can´t tell for sure right now because it worked sometimes before.
UPDATE: right after switching from Firefox to Rhino: same problem again.
pascal
(Pascal Golay)
September 2, 2021, 3:11pm
13
Hi David - one other thing to try is to force ‘high performance’ mode in the nVidia control panel.
david.adam
(David Adam)
September 2, 2021, 3:20pm
14
That doesn´t work either. Maybe my Dell is just to old…
pascal
(Pascal Golay)
September 2, 2021, 3:24pm
15
One more - as a test, disable Vray and VisualArq in Options > Plug-ins page and then close and restart Rhino. Any better? But yes, the hardware is being pretty hard pressed by the larger files, is my guess.
david.adam
(David Adam)
September 3, 2021, 12:07pm
16
Disabling Vray and VisualArq doesn´t solve the problem.
Thanks anyway!
