No printer selection in printmask
can you tell me, where I can select any printer in the print window?
There is no selectable box :frowning:
printing leads only to save a PDF.
Even some restarts did not show any printer selection.
version 6 SR5
6.5.18132.5131
regards yogi
Couple of things to try -
If you click in the area where the printer dropdown should be (just above paper size), does anything happen?
If you pull down the bottom of the Print dialog to make it longer, does anything else show up?
If you have English installed, if you switch to that and restart Rhino is it any different?
Also maybe you could run SystemInfo in Rhino and post the results here…
–Mitch
Hi Mitch,
1.: nothing happen
2.: nothing happen
3.: german version
Systeminfo
Rhino 6 SR5 2018-5-12 (Rhino 6, 6.5.18132.5131, Git hash:master @ b8b8945d46018b7f175f54f1e384ede46df9745d)
Licence type: Kommerziell, Build 2018-05-12
License details: Cloud Zoo. In use by: xxxxxxxxxxxxxxxxxx
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Machine name: MICROHELIS-1
AMD Radeon ™ R9 390 Series (OpenGL ver:4.5.13506 Compatibility Profile Context 23.20.15017.3010)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50
Driver Date: 1-31-2018
Driver Version: 23.20.15017.3010
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\RhinoCAM 2018 for R6\RhinoCAM 2018 For Rhino6.0.rhp “RhinoCAM 2018 - The cutting edge CAM plug-in for Rhino 6.0 from MecSoft Corporation”
C:\Program Files\SimLab\Plugins\SimLab Rhino 6 Integration\SimLabComposerIntegration.rhp “SimLab Composer Integration”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCAM 2018 for R6\RhinoArt1FileExporter For Rhino6.0.rhp “RhinoArt1FileExporter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
regards yogi
got help from user-support.
Installed english language package, and restart Rhino3D.
Printer selection appeared and seems to be available after switching back to the german language.
THX to support and Mitch, who also suspected that
regards yogi
