I am working on a GH sketch (See attached file below) which is a parametric system for making vehicle frames. Im trying to create a UI for this using human UI.
I am getting the following error on a UI container object. Solution exception : no parameterless constructor defined for this object. Have no Idea what this is and why it should be showing. I’ve done everything right.
Sorry, didn’t see this until right now. Your problem here is that you’ve connected the value listener to the stack element, when you need to be attaching the elements themselves to the stack container. I’ve corrected this issue for the sliders and added a launch window for you to demonstrate.
Hello @marcsyp , I am very sorry for reviving this old thread. I am trying to learn the basics of Human UI in Rhino 8 and getting a similar error with the Expander UI Container component. Any idea what I could be doing wrong? I appreciate your help. Thanks
Solution exception:Cannot dynamically create an instance of type ‘HumanUI.UIElement_Goo’. Reason: No parameterless constructor defined.
