Hi
I would like to as the following:
I installed Rhino 6.16 however I am there is no Options > Plug-ins ( not exist)
also I installed v-ray … I am getting error loading - vrayforrhino
could you please advice
Hi
Hello - can you please run SystemInfo
in Rhino and post the results?
Rhino 6 SR16 2019-7-9 (Rhino 6, 6.16.19190.07001, Git hash:master @ 06b69c5cc21d880aa793a5a7cfd454a66f6213bb)
License type: Commercial, build 2019-07-09
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: LAPTOP-LO8AAETC
Hybrid graphics system.
Primary display: Intel® UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-19-2018 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 (NVidia) Memory: 4GB, Driver date: 9-12-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 399.31
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-12-2018
Driver Version: 24.21.13.9931
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.17.19235.15041
Hello - I would close Rhino, open the Windows control panel > Ador remove programs, locate Rhino 6, click, > Modify > Repair…
And see if that does anything good.
thank you brother … I did the same but is is not working
do u think it is strange that I have only one path under the pligins
Rhino plugins
If the repair didn’t work you can try:
.rhp
onto your open Rhino.Grasshopper
folder under the plug-ins folder, and drag the right RHP file onto your open Rhino.Did none of the plug-ins load? Please check again Tools > Options > Plug-Ins
