No mass properties for a hole?
Hi all!
I’m having an issue when trying to use the “Area” component on certain round edges. The component shows an error. “Deconstruct Arc” doesn’t work either. Is this a modeling issue? Any help is appreciated. Thanks!
cbass
Screenshot%20-%2017_05_2018%20%2C%2011_28_41%20AM
No mass properties for holes.gh (1.5 KB)
No mass properties for holes.3dm (439.0 KB)
the surface where these holes are in acts as being not planar. If you extract that surface and make a bounding box, you’ll see that it makes a box instead of a rectangle. Even though the box has a height of 0.00". The bottom surface does not have this issue.
Edit: you can also correct it by extracting the top surface and use SetPt in Z direction and join back together.
Wonderful. Thanks for the help!
