Hi Jon,
I’m pretty sure we have fixed this error in the upcoming 2.6 version, but just in case, could you send that model to visualarq@asuni.com? we will check it out.
Jon, the file attached doesn’t look like the one in the image above. I guess it just contains a few walls. In any case, I’ve tried to run the mirror command on the walls in there and it works fine (with VA 2.6)
I’m having this problem in 2.5 as well. I’m glad the issue had been resolved in VA 2.6. When will it be released?
It will be released very soon, in the meantime you can already test it.
Take a look at this thread: Slab materials
