No intersection possible? (between closed surfaces)
I have two objects in Rhino: a floor (green) and a rugbyball-shaped object (red).
Here is a wireframe and shaded view:
The red object is a closed surface. The green object is a closed polysurface.
In the end I’m trying to trim/cut the red object out of the green object (already tried BooleanDifference, Trim, Split, BooleanIntersection; although not all of those have the desired end-effect).
Using the Intersect-command, Rhino couldn’t find any intersections.
However, looking at the drawing, the objects clearly intersect.
Why does Rhino think they don’t intersect?
And how can I make the intersection?
Thanks in advance for the advice!
(drawing is attached)
no intersection possible.3dm (191.3 KB)
Which version of Rhino are you running? Here on 5.12 I get two intersection curves.
Next question, how did you make the red object. The What command says it’s a revolve but seeing that there is a seem going all the way around, I’m wondering if you revolved a closed curve instead of just half of it.
The problem is your “rugbyball”. Looks like you revolved a full ellipse, which produces a double surface. Turn on control points, you will see all are doubled. Try revolving a half-ellipse or using the Ellipsoid command, it should work better.
–Mitch
As far as I can see Rhino 5.0 (64 bit)
I indeed revolved an ellipse curve.
Will try revolving half a circle, and the ellipsoid-command
Will keep you posted.
Thanks for the tips!
@wim, @Helvetosaur: a “double” ellipse was indeed the problem. It works perfectly now.
Thanks for the suggestions! (and the quick response!)
@Helvetosaur : can you tell me how can I turn on the control points?
Thanks again!
F10 or the icon in the main toolbar that looks like this:
@wdvl
_PointsOn
_SolidPtOn
are the control points commands.
In that case you should update to the latest Service Release.
