No funciona Quadremesh
Hola a todos,
estoy usando la version 7 de rhinoceros pero cuando quiero usar quad remesh me dice que no existe el comando
Hello, what language is your Rhino installation using? Have you tried typing _QuadRemesh with leading underscore to use the English language command?
Graham
I have the same problem. I also have Rhino in Spanish, but I tried all the commands, also with the underscore. I have reinstalled and recovered the system and it does not work. I changed the version to English and it works fine once again. I think the problem is in the Spanish version.
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
