In the latest sr I don’t see any controls for exposure is it not hooked up?
RM
Hm… as far as I know this is working. Can you try closing and reopening Rhino and verify it’s still missing?
Hi Pascal,
Yep still missing even after a shut down.
RM
Sys info
Rhino 6 SR22 2020-1-28
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Hybrid graphics system.
Primary display: Intel® HD Graphics 530 (Intel) Memory: 1GB, Driver date: 11-18-2018 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 960M (NVidia) Memory: 4GB, Driver date: 8-13-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 399.01
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-13-2018
Driver Version: 24.21.13.9901
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.22.20028.13281
E:\rhino3d\BoltGen\BoltGen1_62.rhp “BoltGen” 0.0.0.0
E:\Downloads\elefront411\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.22.20028.13281
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.12.17.906\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.22.20028.13281
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.22.20028.13281
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\SectionTools (fbdb1d7f-8cfb-42c1-9858-87cb6315932c)\2017.10.11.570\SectionTools.rhp “SectionTools”
Ah ah I figured it out you have to have show this panel by default checked and render again then it works.
Looks like a slight bug there that needs tuning one should not have to do that.
RM
Hello - so far mine just shows either as the window opens or if I ask for it - are you saying it is not on by default, and you turn on the panel, it shows up blank?
"Hello - so far mine just shows either as the window opens or if I ask for it - are you saying it is not on by default, and you turn on the panel, it shows up blank?
Yes.
I have to check the box “show this panel by default”, exit the rendering and re-render then the controls show up but if I uncheck that box even after using the controls then they again don’t show up and I have to go through the above procedure again to make them show. Looks like a bug to me maybe you are on a different sr than me?
Thanks for your help,
RM
