No curves, edges or isocurves showing
I just started to use rhino 8, used previous versions for a long time.
I have an issue showing curves, edges and isocurves. whatever i try; display options, everything seems okay.
the curve is there when i search with selCrv but it only starts to become visible if i extract a surface from this curve
the weirdest thing is that when I change the color of one side of the solid the edges appear out of nothing.
can someone help me how to enable the edges and curves?
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Evaluation, build 2024-01-09
License details: Stand-Alone
Expires on: 2024-04-13
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 16Gb)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 10-14-2020 (M-D-Y).
Primary OpenGL: Radeon Pro WX 3100 (AMD) Memory: 2GB, Driver date: 8-29-2022 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 22.20.16.03.220829
> Integrated accelerated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 8-29-2022
Driver Version: 31.0.12016.3004
Z-Buffer depth: 24 bits
Total Video Memory: 9905 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
Hi -
I’d start by getting the most up-to-date drivers for that GPU. When you run the Rhino Notifications command, you’ll get a panel with links to AMD’s driver pages.
that worked! I can now see my curves and edges properly. Thank you!
Hi
I have same problem in Rhino 8, no curves are shown, but are in a square or box with dotted lines.
System Info gives this if that gives any idea of the problem??
thanks in advance
-bs
Rhino 8 SR5 2024-3-12 (Rhino 8, 8.5.24072.13001, Git hash:master @ e3530849b75f00b2b977766a567ae29b055837e9)
License type: Commercial, build 2024-03-12
License details: Cloud Zoo
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 8GB)
.NET 7.0.0
Computer platform: DESKTOP
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.1 (primary GPU’s maximum)
Anti-alias mode: 4x
Vendor Name: Parallels and Apple
Render version: 4.1
Shading Language: 4.10
Driver Date: 3-1-2024
Driver Version: 19.3.0.54924
Total Video Memory: 4191584 KB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24072.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24072.13001
Your problem is going to be the use of Parallels. It may work, but not fully.
Also, it isn’t supported: Rhino - System Requirements
Well Rhino 7 works perfect
bs
Rhino 7 and Rhino 8 are not the same program…
Hello! I just started using rhino on my laptop, i discovered that my lines does not show unless i select them. What should i do?
Rhino 8 SR17 2025-3-7 (Rhino 8, 8.17.25066.07001, Git hash:master @ b14fcd901289f8715631debb308bc919a4988e07)
License type: Evaluation, build 2025-03-07
Expires on: 2025-06-15
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Computer platform: LAPTOP - Unplugged [83% battery remaining] ~545 minutes left
Primary display: Qualcomm(R) Adreno™ X1-85 GPU (Qualcomm Incorporated) Memory: 0MB, Driver date: 11-20-2024 (M-D-Y).
> External USB display device with 7 adapter port(s)
Primary OpenGL: D3D12 (Qualcomm(R) Adreno™ X1-85 GPU): Microsoft Corporation. OpenGL Ver: 4.6 (Compatibility Profile) Mesa 24.3.0-devel (git-370ac36d5d)
> No graphics device is being used for OpenGL
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Vendor Name: Microsoft Corporation
Render version: 4.6
Driver Date: 11-20-2024
Driver Version: 31.0.84.0
Total Video Memory: n/a
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25066.7001
This machine does not meet our system requirements.
if it is brand new and you need it for Rhino, I’d return it and buy a different machine that fits this description-
So you mean that I have to buy another laptop to use Rhino? Is there no other way to solve the problem?
at the moment no.
this system does not have the supported hardware needed to run Rhino. A different machine is the only path at this time.
have you read our system requirements?
Hej Emil -
In some cases, updating the drivers for the GPU might help some. As Kyle noted, however, that platform is not something that we currently support.
