Autosave doesn’t seem to work if the file is open from a network. Is that a known issue?
Hi Arch- can you try running the Autosave command directly with one of these files open and see if that produces a file in the autosave folder? Keep in mind that Autosave files are deleted when the current file is successfully closed.
