Niggling little bug with CurveBoolean
In the attached, on the construction layer, you will see some guidelines. I want to create 7 new independent regions from the guidelines, so I use CurveBoolean CombineRegions=No and DeleteInput=None (result on the Regions layer)
Problem is sometimes the resulting polylines have stacked control points at the corners - when you go to extrude them you get a “self-intersecting curves” warning and the resulting extrusion - if you go through with it - has a bad surface in it. In the example given it’s the lowest two wedges which get this (marked in red), but depending on how I do this, sometimes it’s one of the others.
Simplifying the curves after (always a good idea with CurveBoolean anyway) does not help in this case. However, what seems to help is exploding the original construction curves before doing the CurveBoolean…
–Mitch
CBError.3dm(73.3 KB)
Hi Mitch,
I see it and will get it fixed.
Thanks,
Chuck Welsh
Robert McNeel and Associates
Fixed. Should be in SR7.
Thanks for the report,
Chuck
