NGON plug-in not working with Rhino 8 Grasshopper on MacBook Pro M1 Max
I ll try to compile ngon for rhino 8 this weekend.
Rhino 6, 7 plugins dont work on 8.
Wow, that would be awesome!
I might have to buy serval coffes for you then :wink:
Plugin is updated for Rhino8 via .NET 7.0 :
Install it using Package Manager:
Examples are on food4rhino:
GitHub:
petrasvestartas/NGon
:beers:
@Petras_Vestartas 3.3.0 doesn’t work for me in rhino8 on windows, 3.2 works fine in rhino 8, thanks for the plugin
What does it mean, does not work?
Do you have latest Rhino? And did you delete previous versions?
Thankyou for the quick reply. yes i deleted the previous versions and i have the latest service release of Rhino commercial 8.13.24317 , still 3.3.0 doesn’t appear in the grasshopper tab, earlier i down graded to 3.2, it appeared in the grasshopper tab but the boundary first flattening component took a lot of time to compute (1 second for mesh with two triangles) and eventually crashed for larger meshes, i have set my dotnet runtime to NETFramework and NetCoreVersion=v7 in rhino 8. Given this, earlier to the update last week it worked smooth for my workflows.
Do you see any any error messages? Weird, I tested on my mac and windows, both works. What are specs of your computer? 3.2 should be used on Rhino8, due compoletely dofferent architecture, but 3.3.
@nathanletwory Could you help to debug why NGon 3.3 version is not loading to @libish.1234 ? I got rid of all C++ dependencies and compiled for .NET 7.0.
hi , for 3.3 in rhino8 commercial in windows 11 there are no error messages ,i installed through the package manager , the Ngon plugin doesn’t show , for 3.2 seems slower than before for some reason(by a huge margin). my laptop is HPZBook Fury , 2.1 ghz and 64 gb ram, Nvidia RTX ada 5000 gpu
Can you share the .yak file you uploaded to the package manager with me in a DM?
I didn’t realize this is a grasshopper-only plug-in. When I install this, restart Rhino, then it works just fine over here:
Thank you.
Any ideas why @libish.1234 cannot run it, can he somehow debug it?
Well, @libish.1234 could start with running the Rhino command _SystemInfo and posting the result in a reply here.
I was assuming MacOS here, but rereading this is on Windows. I will check tomorrow on my own Windows box, it is getting late here.
Thank you:)
thank you sir! We owe you some espressos…
readout from system info , Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Commercial, build 2024-11-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9261.0
Computer platform: LAPTOP - Plugged in [58% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
Primary OpenGL: NVIDIA RTX 5000 Ada Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
, using 3,2 ngon which previously worked in rhino8 luckily ,
it ran for 8 hours and then i had to end task the Bffcommandline utility in Taskmanager to stop the component,
the process exited with the following error, Solution exception outside the bounds of the array
perhaps some brewskis
As far as I can tell NGon 3.3.0.0 installs and works just fine on Windows 11
Thank you:)
Send me a mesh you use as input.
