NGon_3dtiles
Hi! I need to project this 3D tiles
into this
surface. How can I do it with NGon nod?
1.3dm (179.4 KB)
I had some problems with your target surface and rebuilt it.
I also rebuilt the tile and internalized all geometry
surface_morph.gh (64.2 KB)
thank you a lot)
But there is a problem with tiling in this area
I heard that with this plugin you can do it correct
surface_morph.gh (66.3 KB)
If you have a quad based unit you want to map, you will need a quad division of your surface, not ngons.
Instead of this revolve based surface geometry you have with the pinched faces at the ends, you could start from a SubD object to get more regular shaped quads:
Thank you a lot!)
