NextViewport bug on Mac
Hey,
I’m having an issue with the !_NextViewport command. I have it mapped to cmd+W, and it works fine when I make a new file. However, when I use an external monitor and set up the secondary screen with a Floating Viewport, the !_NextViewport command only lets me cycle through two or three views before getting stuck on the Four Viewport view.
Tl;dr: !_NextViewport stops working when I use an extended monitor with a floating viewport
Hi Alex -
I’m seeing something that’s not right but I’m not sure if I’m seeing the same as you do.
At one point I got NextViewport to do nothing at all, but that was after having switched to other applications and then back to Rhino. This is not something that I could reproduce after that one time.
Just to make sure, is this strictly related to using a keyboard shortcut on your end, or does that also happen when you just type NextViewport once and then hit Enter to cycle through viewports?
Hey Wim,
Thanks for the response. Typing NextViewport and cycling with Enter gets the same result. I made a new file and was able to recreate the issue. I made a screen recording so you can see when the command suddenly stops working after I make a Floating Viewport. I’m also uploading the file.
NextViewportIssue.3dm (4.8 MB)
I guess my real issue is that _NewFloatingViewport is buggy in general? Every time I move from my extended monitor back to my main screen to do something like change a layer, Rhino makes me click the layer twice and often hits the adjacent radio button by mistake.
