Newtonsoft.Json Issue with JObjects
I have been having issues with the Newtonsoft.Json included in the System/netcore folder not returning a JObject that I am trying to get after parsing from a json file (JObject beam_data = JObject.Parse(File.ReadAllText(fileName)). My plugin works when debugging with visual studio but when I load the plugin into Rhino it stops running at that line of code?etdo
I included the Newtonsoft.Json.ll in the XML with the folllowing lines of code and set rhino’s runtime = NETCore, have am using the Newtonsoft.Json.Linq namespace. Any help would be greatly appreciated, thanks.
    <Reference Include="Newtonsoft.Json">
	<HintPath>C:\Program Files\Rhino 8\System\netcore\Newtonsoft.Json.dll</HintPath>
	<Private>False</Private>
</Reference>
Probably can remove this post…I found that my problem was because I had an incorrect file directory path…and also I don’t think this should have been posted to the rhino developers forum. The Newtonsoft.Json works just fine!
