Newbie Questions - connecting curves in space
I am trying to connect a curve in the XZ plane to a curve in the XY plane, and keep the curves in their respective planes - that is stretch the highlighted curve to connect to the non highlighted curve.
Is there a nice and somewhat easy way to do this?
Thanks
Hi Carl- always best to include an example file if you can. Here it looks like Extend with the ToPoint option may help.
Just tried uploading the file – it’s too big.
I’ll try what you mentioned - thanks
Hi Carl - just export the relevant bits to a new file and post that.
Gibson '59 Les Paul test 02 to Forum.3dm (142.5 KB)
I will be picking away at the geometry - the profile curves have wayyy too many control points…
Yes…
Thanks!
I started doing the same with degree 5 curves.
