Newbie Help - Rhino 3D 4.0
I’m new to Rhino!
I’m trying to create a rectangular prism with 3d text cut partially into it, sort of as if it were engraved.
I have managed to create a rectangular prism, and I have created the text over top of it as curves, but I don’t know how to make the text cut into it.
Any advice would be greatly appreciated! I couldn’t find a tutorial explaining this type of action.
  • Dorota
Hi Dorota, love your avatar,
You could check out TextObject in the help file rather than text to create a solid then use boolean difference to subtract the text from the prism… along those lines
Hey, thanks for your response.
I created 3D text and put it inside my rectangular prism, but when I try to use boolean difference, I select the rectangular prism first then the 3D text second… it says “Objects do not intersect. Nothing done.”
But my 3D text is CLEARLY inside my rectangular prism. What am I doing wrong?
I realized the boolean difference only works if the 3D text goes through the surface of the rectangle. My text was mostly hidden inside.
