I’m new to VisualARQ and Rhino, and I’m finding it extremely frustrating. Is there a good guide on how the style hierarchy is supposed to work? What are the best practices for objects, sections, plans, levels and layers?
I can’t get it to work and I don’t understand the logic behind it. I set things up, but I can’t see what I changed on screen or in the layout, and what I see in the layout is not the same as what comes out on paper. In general I’m very confused by the process.
Example: a simple steel structure (VA beams/columns). In a plan view on a layout detail, the cut columns should print solid black with a heavier outline, and everything in projection thin. Instead everything prints with the same thin lines and no hatch, no matter where I change the settings (layer, object, style, Print Display on/off). Screenshot / file attached.
Background: I’ve used AutoCAD 2D for a very long time, plus SolidWorks, SketchUp, 3ds Max and others. I’m looking for a productive workflow, especially for BIM. I tried BricsCAD BIM and gave up. Rhino itself works for me, but BIM functionality would help a lot – as long as it works. I’m not yet convinced by VisualARQ, but I want to give it a solid chance.
If someone could point me in the right direction, or give a rough outline of how things should be structured for reliable, flexible yet controlled output, I’d be very grateful.
Hi @Jernej In order to help you, I may require the file you are working with and some screenshots or indications about how the printing result should be.
Just some tips regarding the option to print drawings with Rhino/VisualARQ from the paper space.
Use the Hidden display mode inside the detail view, to ensure you can print the view in a good quality vector output.
Use VisualARQ Cut Planes (from the Level Manager) or Section lines (for vertical sections) to show the model in section.
VisualARQ 3 uses the Rhino section styles to assign attributes to the section boundary and area (hatch pattern, color, etc). However, in the section styles dialog, it is only possible to edit a Boundary Width attribute that is used for display purposes, but it is not reliable as a printing width. This has changed in Rhino 9 (there’s a new Print Width attribute for the section boundary). But in Rhino 8, the only way to control this is using the Print Width attribute added by VisualARQ, that can be found in the Section Attributes panel:
As regards the logic behind the hierarchy of attributes in VisualARQ objects, just think about them as Rhino blocks, where each component is a piece of geometry inside a block definition, that would be the object style. This post explains this in more detail: What does value By Parent mean and how does it work? - VisualARQ
I’m slowly wrapping my head around the logic. The block analogy helps. As I understand it now:
I set a low Print Width on the object style (e.g. 0.05), which acts as the general width for the whole object, including hatches.
Then I set a higher Print Width for the section boundary of the specific component (e.g. the structural layer, 0.35). That gives me the differentiation I need. If I don’t do it this way, the values seem to be ignored.
It often looked fine on screen but not in the PDF, because PrintDisplay was off. With it on, screen and PDF now match.
Hatch by layer works if the component is set to By Layer in the style. What does not work for me is overriding the section hatch per detail (only print width can be overridden). Is there a recommended way to show different hatches for the same model in 1:50 and 1:100 sheets? Would 2D plan/section views with view style overrides be the intended approach?
I know I’m complicating things, but modeling was never my problem. Drawing output has always been the most frustrating and time-consuming part in every program I’ve tried. Here I have the feeling you actually work with users, so I’m hopeful I can build a system.
Two issues I noticed:
In the latest evaluation version (3.12.2.14590), in Hidden display mode I can’t select any object or sub-object. (Someone mentioned this before.)
Annotation objects (my elevation marks) are hidden behind the section hatch in plan and section views. What is the right way to deal with this?
I’m using the evaluation version, since I can’t afford to buy before trying. I’m happy to send a file and screenshots.
Hatches, when they are used in section styles, are printed (to vector output) as Hairline width, regardless of the Print width assigned to the object or to the section boundary. In Rhino 8 it is not possible to control that, but in Rhino 9 it is.
Section hatch (as section style) per detail is a missing feature in Rhino. The Rhino Layer states might be able to handle this but I after some attempts I haven’t been able to get it.
The VisualARQ 2D plan/section view overrides may work if you use the same hatch pattern for all the geometry (it is not possible to override only the pattern scale without choosing a pattern).
In the Document Properties > Hatch, you can enable the Hatch scaling if you want a uniform scale for all hatches in the page layout regardless of the scale of the Detail view. If that setting is not checked, the hatches will be printed according to the scale set to the hatch and the detail scale.
Yes, this is an issue we are currently working on to fix. It fails in page layouts only.
There’s no friendly solution for this. In some cases you can use the BringToFront command on the Annotation object, but this will make the annotation be displayed on top of the rest of the geometry in the model, not only above a particular hatch or other object. The most straight-forward option to handle this is to move the Annotation object 1mm upwards (or move the hatch 1mm downwards).
