Newb_Help_TIA
What is the best way to close this model and make it a solid?
Display_REV1.3dm (349.4 KB)
Extract the edge, flatten, and rebuild it.
Extrude:
Split the extrusion with the main volume, delete what you don’t need:
Thanks.
Does joining this after create a solid body?
Yes. I forgot about this last step.
Nurbs surface modeling is a lot like making models with sheets of paper.
Think about it this way, If you had nothing but a stack of 8x10 copier paper, scissors and tape…how would you make the model? How would the primary surfaces connect at the edges?
Once you sort that out the rest is simply adding the transitions (fillets, blends, etc) but the paper sheet and tape workflow will get you the basic forms you need to build from there.
