jokamm
#1
Is there an official name for the new feature that allows you to transfer/propagate Nicknames?
(new to 1.X as far as I can tell)
Drag out a wire and tap Alt, and the wire turns red. It will now cause the downstream component to inherit the Nickname of the connected node.
I discovered it by accident, and couldn’t find any references to it on the forum. But that could just be insufficient searching.
Rickson
(Rickson)
#2
Its called a Relay. Similar to Autograph by the Elefront crew.
I like the Relay a little better due to being able to see the text while the icons are displayed.
Rickson
(Rickson)
#3
You can also double click a wire to create and cntl+alt+down arrow to remove.
jokamm
#4
Yes, I’m familiar with relays. That’s not what I’m talking about. Relays don’t automatically inherit names. Except from each other
Er… it’s officially called… ehm… Copy. Name. Mode?
Yeah, copy-name-mode, that’s it.
