New User having trouble getting started
New user, just downloaded Rhino 7. Runing windows 10. All viewports are black. Cant do anything. From very first log on. Where do I start?
If you can, type SystemInfo at the command line and copy/paste the results here.
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Educational, build 2023-02-27
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 3.9Gb)
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) HD Graphics 4400 (Intel) Memory: 1GB, Driver date: 2-21-2018 (M-D-Y). OpenGL Ver: 4.3.0 - Build 20.19.15.4963
> Integrated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.3 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.3
Shading Language: 4.30 - Build 20.19.15.4963
Driver Date: 2-21-2018
Driver Version: 20.19.15.4963
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
OK, unfortunately your system is far below the minimum requirements for running Rhino V7, and on top of that, your video drivers are very old (2018). Intel considers your system “end-of-life”. You might try updating your video drivers - seems the most recent one is from end of 2022, but even then I am not sure it will work correctly.
Unfortunately, you really need a better computer to run Rhino.
Thanks for your input. Ill have a crack at that upgrade and if not guess it’s time for an upgrade then.
