New UI: How to move the panel tabs to the other side
I noticed that the tabs for the panels always dock on the side away from the viewport. Is there a way to dock then so that the tabs face the viewport? Like this:
Thanks,
Dan
Hi -
I’ve added that request to RH-69840 Provide an option to display container tabs at the top when docked on the left or right side
Related to this: the magic pin [to hide the panels] is missing when docked on the left [in Mac at least]
Yep- right now, this is restricted to the right hand dockers.
I’ll see if I can find out what the plan is, there…
+1 on the ability for vertical tabs to be on the other side as well.
(and still hope horizontal tabs will be available in the new UI as before)
Thanks Wim.
RH-69840 is fixed in the latest WIP
Thanks Brian.
Maybe I’m missing something, but I don’t see how to dock the tabs vertically, but on the other side. Is that possible with the latest WIP? I do see the horizontal setting.
Thanks,
Dan
Hi Dan -
That’s not yet possible, no. RH-69840 only took care of that initial request in the report.
As of now, the horizontal/vertical position is a global setting and applied to all containers so that probably still wouldn’t do much good if you were able to get them on the other side…
At any rate - does this one cover what you need - RH-67353 Docked panel containers don’t have properties for tab positions
Hi Wim,
RH-67353’s comment by John sounds like what I’m after. Overriding the tab locations per container would be the solution.
Thanks,
Dan
