glen
April 6, 2016, 9:31am
1
Hello, I’m new to Rhino and encountered this problem that the surfaces do not align after I offset them.
Here’s what I did
Create the surface
Project gridlines onto the surface to obtain the
Extrude the curves for thickness
Offset the surfaces from the extrusion
Is there something that I am not doing right? Please advice thanks!
shelter2.3dm (3.1 MB)
Project gridlines onto the surface to obtain the ???
What is not aligned as you expected?
pascal
(Pascal Golay)
April 6, 2016, 3:30pm
3
Hi Glen- I’m not sure where the problem is but I suspect that what you want is for the extrusions to end at a offsets of the original base surfaces, is that correct?
Like this?
glen
April 6, 2016, 4:53pm
4
ah yes that was what I was trying to achieve. sorry if my information has been unclear
pascal
(Pascal Golay)
April 6, 2016, 5:30pm
5
Hi Glen - one way would be:
Make the full grid as 2d on the CPlane, with offsets as you like them,
Extrude these curves through offsets of the target surface
select extrusions, target and offset and CreateSolid
Simplified example- shelter2_PG.3dm (1.4 MB)
