I just started using Rhino 6 WIP and have two questions:
Where did the information bar/command history line go? The one that’s right above the command line in Rhino 5. I feel lost without the crucial feedback it gives, especially if something fails. How do I turn this feature back on?
When selecting curves Rhino 6 shows the control points by default. How do I turn these off? PointsOff does not prevent them from showing.
As in RH5, the command history in RH6 is part of the same window as the command line. You can just pull the border under the command line down until you see as much of the history as you want.
You can turn that off with these settings:
Rhino Options > Mouse > Selecting > Allow selecting objects with points on
and
Rhino Options > Mouse > Selecting > Turn on control points when selecting a curve, light or annotation
