New to clipping sections and Clipping drawings
HI, I’m new to “clipping Sections” & “clipping drawings” and am attempting to follow the Rhino instructions found at:
After down loading and using the supplied Drawing I ran into two problems.
1) Following this instruction;
  1. "At the Place sections… prompt
    1. Select the Dir=X and change it to CPlane.
    2. Type 0,0,1.2. Press Enter twice. It will place the section 1.2 mts in height."
The result is a 0 Z axis depth instead of the 1.2mts depth as portrayed in the instruction. Why? I’ve followed the instruction word for word. Does any one know how I can correct his?
2) The next problem instruction for; “Create The Drawing” > Is “At the Placement point prompt
, snap to the point behind the building.” (shown in the illustration)
There is no Point in the supplied drawing and I cannot place one that will show in the perspective view. I can place it in the Top View but it will not show in the Perspective view. I know it’s not critical for placement I just need to know why it will not show?
I’ve also opened an empty drawing (New) and was able to place a point at will that show in any view.
Can someone help with me with this ?
Thanks
Fred
Clipping plane/section drawing orientation depends on the starting viewport.
So Coordinate 0,0,1.2 may change depending to the viewport. If you start from top view 0,0,1.2 means 1.2 in Z .
Thank you , I’ll try that.
