A couple issues I’ve noticed. Sorry if they have been mentioned as I don’t have time to search and read much.
1… When using a dimension command and after I have picked the two points, the dimension number and arrows are black. Then the final click to place the number, it turns the number and arrows to the layer color. So I use a black background and this “invisible” dimension number is very annoying.
2… In V5, if we had a dimensions selected we could goto the properties and quickly cycle through the styles with the up/down arrow keys. In V6 we have lost this ability. Same for text, I can’t cycle through fronts.
Those aren’t written down anywhere that I know of.
I’ll fix the layer color part.
For the dropdown list, I’ll have to look at what’s available in the new interface stuff we’re using.
have checked some other parts of the drawing and strange some leaders
are ok some almost and some have no arrow and they are made with the
same script…
Thanks. I’ll look at your file.
Converting leaders that are rotated and have text horizontal is a specialized operation that I need to put off for a while. When I get through some of the more common things I can probably do a better job with the leaders
today, i always save my work also as a 5 version, but today it went a bit wrong , the text i had added in(version 6) is not visible any more in the 5 version, i can in the layer box select the layer and it shows a amount of text , but no text visible , strange as it Was visible before what to do ? enclosed the files , layer names has the text
maybe not the right topic , but i think the files created with V6 are very large as compared to version 5text v5 not visible.3dm (273.3 KB) text v6 visible.3dm (283.3 KB)
btw this text appears when saving CRhCommandPropertiesEventWatcher::OnEndCommand::InCommand(1134416872)
Command: _CommandHistory
@robo - I’m really sorry about that. It’s my fault.
Here’s a python script that you can run in V5 to fix the text.
The bug in Rhino is fixed and it’ll be in a build in a few hours.
Would you like to get a fixed build when it’s available? Let me know about that.
There’s a chance. I liked that feature too.
There is a bug report about it on file. It’s not easy to do, especially with the library we’re using for making dialogs now.
It will make it to the top, but not right away
Rob - What, exactly, did you do to get that result?
I read your org text v5 file with v6 and saved as v5 and got this file: new text v5.3dm (133.7 KB)
Which looks right when I open it in v5.
well nothing special yes it looks right , what i did was , opend the v5
file in v6 , then worked around a bit also nothing what has to do with
text, saved it as av6 small then saved the same as v5 large , opening
the v5 with v5 then you see the resultal text is wrong scaled
fortunatly the little thig i did was to get it in v6 again to try it ,
had a v5 backup file so no big deal, but … it is weird
opend the r6 file , saved it as a r5 small, when opening the r5 small it
seems ok but all text was gone , so used the fixtext script… now all
text is wrong scaled as you have seen , so i could repeat the problem .
