Prior to Tuesday’s update, there was a different splash screen that allowed one to set a default template file. Now there is an entirely new splash screen and no such option is apparent. Also, my previously (prior to the most recent update) selected default template is no longer being used when I create a new file. Am I missing something?
Hi Kaleb -
No, this is under construction.
Thanks Wim - I think we can all agree this is a rather important feature to have working properly, no? Is there a timeline for the fix?
Hi Kaleb -
As far as I can tell, getting a functional splash screen is high on the agenda.
The issue with setting a default template from that splash screen is on the list as
→ RH-98094 Splash and Greet: No Way to Set Template
The related issue where running the New command doesn’t let you set a template to use is filed as RH-98164 New: Can’t Pick Template
That one hasn’t been scheduled yet…
