brian
(Brian Gillespie)
December 27, 2016, 11:25pm
8
Rhino WIP 2016-12-27 is now available.
This WIP includes:
It’s a light week as many of us are on holiday
Pullback to cylinder is improved
Wrong message in the GroundPlane panel for Raytraced mode
Keyboard shortcuts only accept one letter in Rhino MAC
CollapseMeshFacesByEdgeLength - dialog won’t come up
And a few more…
Download Now and report any problems in this forum.
brian
(Brian Gillespie)
January 3, 2017, 11:36pm
9
Rhino WIP 2017-Jan-03 is now available.
This WIP includes:
It’s a light week as many of us were on holiday
Meshes with false colours are drawn completely black in Grasshopper previews.
Several crash bugs fixed
And a few more…
brian
(Brian Gillespie)
January 11, 2017, 2:02am
10
Rhino WIP 2017-Jan-10 is now available.
This WIP includes:
Annotation : this release includes a major upgrade to all the annotation creation commands.
CurveBoolean : several improvements to CurveBoolean including a new option to output planar surfaces
Lots of additions to the RhinoCommon .NET SDK
ViewCaptureToFile : several bug fixes
Display : many improvements to display
Cycles : many improvements to raytraced display
FBX file export now embeds textures
Details and more enhancements…
brian
(Brian Gillespie)
January 18, 2017, 3:39am
11
Rhino WIP 2017-Jan-17 is now available.
This WIP includes:
Annotation:
3dm File I/O: Move dimstyle override storage to ON_V6_Annotation
Add options for setting named dimstyle to -Properties for Angular dimensions, Leader, Text
DimOrdinate mirror problem
DimRecenterText changes dimension measurements from model space distances to layout space distances
Dimensions and text conversion from V5
Dragging Layout Dimtext scales the value
Editing Dimension text changes distance from model space to layout space distance
Editing very very slow in Properties
Error making new annotation style
Layout space Ordinate dims have wrong values
Make new Dimensions that use CRhinoRichText
Ordinate dimensions don’t use ModelSpaceScale to draw text
Radial dimensions use the dimension arrow size but should use the leader arrow size
RText - Font changes to Arial when start typing on Chinese Windows
Crash when selecting color for custom backface material
CurvatureAnalysis: Analysis mode persists in blocks
Cycles:
Add support for linear lights
Do not repeat setting in material texture is ignored by Raytraced mode
Paint and plastic materials don’t look right
Raytraced bump map too strong
Raytraced display doesn’t reflect custom materials with textures in color channel properly
Raytraced mode doesn’t show specular highlights
Raytraced mode very dark no reflections
Display:
Black Viewports fixed in some cases
Block outlines hide in Technical, Artistic, and Pen views
Implement ground plane for OpenGL 3.3 core profile
Pen - Block disappears
Shading delayed
SSAO produces dark line on the horizon (where ground plane ends)
File IO:
Bad objects created on open
STEP Import - Messy pole does not get cleaned up
STEP file has super large extents
STEP import should be able to clean up bad edges like this one
STEP import splits closed edges unnecessarily
SolidWorks assemblies - no blocks
Grasshopper on High-DPI monitors
Problems in Gradient component
buttons in sketch toolbar
number slider in sketch toolbar
Grasshopper Mesh Parameter crash.
History: Updates not happening when user interface edits annotation text
Licensing: Many changes and improvements to the process of entering licenses, registering, and validating licenss.
Make2D: A couple failure cases fixed
MaterialEditor: Content UI disappears
Osnap: Mid Osnap is much stronger than other Osnaps
RDK:
Exception thrown when closing Rhino after creating materials with Eto UIs
Floating Editor request
Render:
Render Frame is disabled while rendering
Rendering: Custom material from Glass has Black diffuse channel
Rendering: Some plastic bump patterns don’t tile
Rendering: Too many instances created for polysurfaces by ChangeQueue
Selection: Details should show control points when selected too
brian
(Brian Gillespie)
January 25, 2017, 10:30pm
12
Rhino WIP 2017-Jan-24 is now available.
This WIP includes:
Annotation :
Change “Rich Text” to “Text” on the text dialog
Overridden setting does not revert to default color when set to default
Rhino 5 Text Shifting in Rhino 6
Rhino 5 Text with Fields Shift in Rhino 6
Exploding leader doesn’t preserve locations of parts
Problem in Layout
BoxEdit : Act on block instances
Cycles : Decals broken is latest version
Display :
Add more complex texture mapping modes and decals to the GL33 shaded mesh shader
Ambient light setting is missing from Display settings
Black viewports in Technical mode in WIP from 8-23 and old driver
Block drawing broken for Technical, Artistic and Pen
Block instance with object material set to By Parent draw incorrectly.
Continuous loading of bitmap files when Rhino is idle
File does not open properly
Fresnel reflection not working in Core Profile
Lag when calling open vs selecting recent file
Only joined edges pay attention to display mode settings
SSAO banding during dynamic draw
Shaded display of blocks wrong
Shaded, Ghosted, Rendered broken in latest WIP
Viewport performance slows dramatically with wallpaper image enabled
File IO :
Multi Page PDF options needed
Seam placement in STEP import of closed elementary surfaces
File dialogs do not display all plug-in file types.
PDF Export: - Colors incorrect in Rhino
PDF importing could use a page picker for multi-page PDFs
Grasshopper : Toolbar border cannot be moved at or above 225%
Licensing and Validation : many improvements to the license entry and validation user interface.
NamedCPlanes : Panel is blank before first save
NamedView : Thumbnails are blank when opening 3dm
OffsetMesh : Doesn’t remember the last used settings
Osnap : Only show projected flag if the snap is off the CPlane
Properties : Text and Dots not in scripted Properties
Rendering : Purple ray-trace in Rhino render
Rendering : Settings sections need a controller that supports C#
Revolve : If profile is not co-planar to axis of revolution, surface looses UV coordinates
RhinoCommon :
Add MeshPatch function to RhinoCommon
IsReadOnly needs to be implemented to follow an interface. It should not be exposed
NurbsCurve.Points.ControlPolygon and ControlPoint.Location incorrect for weighted points.
wrap RhinoParseNumber from command line math
SDK :
CRhinoAppSettings::LoadProfile is being called continuously when Rhino is idle
CRhinoDisplayPipeline::CopyToBackBuffer only supports CRhinoDib
SelDup : Make SelDup work with new annotation objects.
Settings : Update Rhino Application Settings Load/Save profile mechanisim
TextObject : Fix command so it does not use obsolete CRhinoTextObject
UVEditor : Zooming into the UVeditor causes the texture to disappear
brian
(Brian Gillespie)
February 1, 2017, 12:58am
13
Rhino WIP 2017-Jan-31 is now available.
This WIP includes:
Display: Shadows on ground plane are noisy
Licensing: Many more fixes to license entry and validation user experience
PDF Import: updated to create new annotation objects.
brian
(Brian Gillespie)
February 21, 2017, 11:20pm
14
brian
(Brian Gillespie)
February 28, 2017, 11:28pm
15
Rhino WIP 2017-Feb-28 is now available.
This WIP includes:
Bug Fixes:
Annotation:
In dimension dialogs read-only edit box at bottom too large (RH-38031 )
Wrapping of dimstyle properties in appropriate sub class. (RH-37642 )
DimRadius: “Horizontal to view” not quite right when TextAngleType is set to “Aligned” (RH-38029 )
DimRadius: leader dives into text (RH-38063 )
DimRadius: TextLocation override isn’t saved (RH-38030 )
Leader: Grip editing leader text does not hide original text while dragging (RH-38026 )
Leader: add arrow images to leader arrow drop downs (RH-37974 )
Arctic display: Arctic mode - Ground plane altitude doesn’t accept negative values (RH-37354 )
Compat: False negative for compat (accessibility modifiers) (RH-37982 )
CurvatureAnalysis: No highlight on analysis modes (RH-36246 )
DPI Aware: Icons in Tutorials dialog have scaling problems (RH-37945 )
Delete: Selection with points on does not work (RH-38024 )
Display:
Incorrectly shows layer color (RH-37994 )
Restore Defaults button doesn’t work on Other Settings (RH-38067 )
Shadows overlay hangs around (RH-37633 )
File IO:
PDF Export: support pre-defined page sizes (RH-37709 )
STEP import messes up in V6. OK in V5 (RH-38068 )
Grasshopper: Components: The ‘Interpolate’ component’s ‘Tangent Start’ and ‘Tangent End’ are not work when degree is 5 (RH-37504 )
HideLayersInDetail: Should allow selection of objects in block (RH-37990 )
MoveUVNOn: Crash when adjusting points (RH-37892 )
OpenNURBS: Add m_bRead3dmHadErrors to CRhinoDoc (RH-37796 )
Print: Text is too big in multi-line dots (RH-38058 )
Rendering:
Ground plane automatic height doesn’t work on opening model (RH-37968 )
RenderArctic should have options (RH-36184 )
SDK: GHPython: GHPython: Add “Transform” to the object type hint list (RH-37977 )
SDK: RhinoCommon: Expose ON_ObjectRenderingAttributes to RhinoCommon (RH-31844 )
Tutorials: Revise sample models to use new materials and rendering defaults (RH-37097 )
brian
(Brian Gillespie)
March 8, 2017, 1:23am
16
Rhino WIP 2017-Mar-7 is now available.
This WIP includes:
New Features and Enhancements:
SnapShots: Named Snapshots feature (RH-37999 )
Rendering: Add more HDRI to the v6 material library (RH-37566 )
Named Position: Selection removed and visibility added (RH-37998 )
Bug:
Annotation:
Add arrow images to arrow type dropdown (RH-37582 )
Dialog box clean-up (RH-37485 )
Mask settings do not match Doc Props dialog (RH-38090 )
Match button in Dimension page of Object Properties (RH-37948 )
MatchAnnotation (RH-38182 )
Move Suppress extension settings (RH-38085 )
Reading attached DWG file - Tolerance value overrides not read (RH-33074 )
Save as DWG - Write dimensions (and everything else) with PlainText instead of UserText (RH-37519 )
TextFields don’t export to V5 (RH-38168 )
Update annotation property pages to match new fields added to annotation styles (RH-37965 )
Annotation: DimRadial:
Export to ACAD - Radial dimensions inside curve being dimensioned are wrong (RH-37518 )
Radial Dimensions not looking Like AutoCAD (RH-37790 )
Annotation: Hatch:
Hatch and History recording (RH-34952 )
Pattern change and History locking (RH-34951 )
Annotation: Leader: Leader arrowhead does not line up with spline (RH-38065 )
Annotation: Styles:
Dialog buggers leaders - Add PlainText for dimensions (RH-37920 )
Document Properties, Annotation Style dialog, add an Apply button (RH-37448 )
Annotation: Text:
Editing multiple text objects requires multiple Undos (RH-38069 )
Failure on glyph U+2672 in Windows Ebrima Font (works in V5) (RH-37649 )
Text command fails when code point is a surrogate pair (RH-38184 )
BooleanUnion: Edge tolerance off from Boolean (RH-38023 )
BoxEdit: Allow Enter to apply changes (RH-38036 )
Cycles:
Bogs things down while editing a material (RH-37955 )
Changing skylight overrides sample count set rough HUD (RH-38144 )
Color picker is shy (RH-38136 )
Custom Skylight env + custom Reflection env + Wallpaper doesn’t update immediately in Raytraced (RH-37932 )
Handle material that has backfacing set (RH-36237 )
Increase the default limit (RH-38120 )
InvalidOperationException (RH-38106 )
Support no-shadows for lights (RH-38093 )
Switching to Raytraced with V-Ray set as current renderer crashes Rhino (RH-37934 )
Too slow starting up in Debug builds (RH-38161 )
Display:
AMD display issues investigation (RH-35225 )
AMD shader variable bug (RH-35826 )
Block shadows are wrong in Rendered mode unless a Polysrf is shown (RH-35879 )
Creating solid hatch turns screen black (RH-38188 )
Dots in hatch always display at world origin (RH-38118 )
Ground plane visibility options are not available in Technical display modes (RH-36301 )
When non-Korean font is used, Korean text gets garbled. (RH-35590 )
Display: OpenGL 3.3:
“Core Profile” displayed in viewports in VMWare (RH-38208 )
Remove all dependencies on TestGLCoreProfile and make GL33 the default if/when available. (RH-38165 )
DotNET: Error message (RH-38102 )
FBX:
Material names aren’t imported (RH-38111 )
colors aren’t imported correctly (RH-38112 )
File IO:
Dimensions created with DimAngle to not roundtrip well when saved as V5 (RH-37554 )
SVG strings need to be culture invariant (RH-38125 )
Geometry Core: :GetTightBoundingBox is Inefficient (RH-38245 )
History: Make status bar “Record History” menu items run macros (RH-38141 )
Installer: Remove the MeshRepair plug-in from the Rhino Installer (RH-38181 )
Lights:
Panel causes a message pump flood (RH-38179 )
Solo state problem with copied group (RH-36196 )
Localization:
Default font not set properly when starting Rhino with language parameter on command line (RH-34262 )
Restore Defaults button selects incorrect font (RH-34415 )
The default font for Korean should be Malgun Gothic (RH-33473 )
Match: Match misses, fails (RH-38149 )
Menu: Needs button revision (RH-37770 )
No Subsystem: Add new MeshRepair code to Commands plug-in (RH-38172 )
OSnap:
On status bar not working (RH-38198 )
Some one shot osnap toolbar buttons incorrectly look selected (RH-38200 )
Panels: Transparency number does not respond to typing (RH-36094 )
Pipe: Default for the second radius (RH-38124 )
PointDeviation: Point count too precise (RH-38101 )
Print:
Leader line prints two different widths (RH-38166 )
Optimized for PDF Mode (RH-4291 )
Print width ignored by hatches (RH-38130 )
Properties: Update new annotation object properties page icons (RH-37022 )
RDK:
Double click -> Properties Page (RH-36193 )
Ensure realtime render engine gets unregistered from view menu (RH-38119 )
Group commands in the UI (RH-36219 )
HUD clicks don’t get eaten properly (RH-38230 )
HUD clicks get evaluated even outside realtime viewport (RH-38231 )
Rendering:
Does not stretch in Rendered viewport mode (RH-37758 )
Jumps when not stretched in Raytraced mode (RH-37761 )
Rendered mode gamma of wallpaper is wrong (RH-37759 )
Setting environment for reflection doesn’t update until the view is rotated. (RH-38081 )
Rendering: Materials: Plastic Material Bump texture not rendering correctly (RH-37625 )
Rendering: Realtime SDK:
Realtime render engine UUID is not exposed in the UI (RH-36250 )
Shadows are on when switching Shaded mode to render with “Raytraced” realtime engine (RH-38163 )
Rhino Installer Engine: Pre-existing package install state doesn’t seem to matter (RH-37876 )
SDK: C++ SDK should provide debug symbols (RH-38186 )
SDK: Python:
Add Create functions to RhinoScriptSyntax (RH-37985 )
RhinoScriptSyntax needs a Create color function and perhaps a Color object (RH-37986 )
SDK: RhinoCommon:
Settings: CRhinoAppGeneralSettings::operator== appears to be incorrect (RH-38159 )
SmartTrack: Settings in Options don’t stick (RH-38142 )
Toolbar:
UDT: flow along surface in WIP (RH-37973 )
Viewports: Misbehaves (RH-38070 )
Zoo: ZooClient’s ClientManager is being instantiated multiple times due to concurrency woes (RH-38114 )
brian
(Brian Gillespie)
March 15, 2017, 1:12am
17
Rhino WIP 2017-Mar-14 is now available.
This WIP includes:
Performance Problems Fixed:
Cycles: Raytraced mode delays things outside of Rhino (RH-38305 )
Bugs Fixed:
Annotation:
Add down pointing triangle aligned right in the style drop down list so the control looks like a DropDown (RH-37591 )
Annotation Object Properties Match button + ESC causes crash (RH-38292 )
Changing font, bold, italic, underline property if selected text unselects the text (RH-38258 )
Text size and model space scale don’t update in properties (RH-38332 )
Annotation: Leader:
“Bottom of first line” leader text position isn’t right (RH-38201 )
Alignment to bottom of first line incorrect (RH-38380 )
Annotation: Text:
Euro symbol missing in text object (RH-38205 )
Extra message on command line placing text (RH-38304 )
Text wrapping is broken (RH-38282 )
Arctic display: Arctic mode - skylight is not on (RH-38269 )
BlockEdit:
Enter invokes Add Object (RH-37911 )
Lock up when bad object created (RH-35961 )
Shows parts in the wrong locations (RH-37204 )
Cycles:
CyclesForPlugins RenderWindow hangs when pressing stop while render is paused. (RH-38272 )
CyclesForRhino plug-in tells methods are missing (RH-38271 )
Memory leaking while toggling between Raytraced and other display modes. (RH-38273 )
Raytraced- all white (RH-37922 )
Render time resets when changing sample count, but render continues from wherever it left (RH-38270 )
Wallpaper image shows as magenta in Cycles (RH-37786 )
Wires move faster than the shaded meshes (RH-38160 )
during startup, the HUD displays “Rendering…” when it’s clearly not. (RH-38162 )
Display:
Cone in studio preview in Rendered tab is black (RH-36101 )
Create display trails with clipping planes (RH-37250 )
Points display disappeared (RH-36439 )
Points in blocks not hidden when disabled for Raytraced (RH-37944 )
Redraw the screen when Ctrl+Tab between views and when coming out of a MaxViewport (RH-37395 )
SSAO shadows slow Rendered mode by ~10x (RH-38185 )
Seems to float in some views (RH-38138 )
Skylight produces black results on VMWare (RH-38241 )
Implement SSAO for OpenGL 3.3 core profile (RH-37377 )
Memory leak in Rendered display mode with object using UV-mapped material (RH-38316 )
Shadows do not work in Technical modes when Core Profile is enabled (RH-38096 )
DocumentProperties: File/Settings/Annotation Styles and Earth Position use license icon (RH-37245 )
Eto: Licence manager “ProgressModal” dialog causes continuous WPF rendering. (RH-38235 )
Gumball:
Gumball scaling increment not the best default (RH-38266 )
Rectangular Lights and Gumball Scale 1D (RH-38207 )
Installer: “Close” button almost hidden in language list (RH-38267 )
Make2D: Add option to group output by source object (RH-38027 )
Panels: Search too tiny. (RH-38139 )
Rendering:
Array index out of range (RH-38224 )
Change tone mapping on the fly (RH-37952 )
RhinoRender - Object too transparent with transparent background (RH-38283 )
Updates only on mouse-over (RH-37993 )
Rendering: Materials: Changing one material color causes all thumbnails to refresh (RH-38259 )
Rendering: Realtime SDK: Realtime display HUD status text usage incorrect (RH-38278 )
SDK: GHPython:
Domain output from rs.CurveDomain is not usable in GH (RH-38363 )
built-in compiler (RH-38167 )
SDK: RhinoCommon:
AutoDelete problem when adding custom environment (RH-38284 )
RhinoCommon SDK documentation out-of-date (RH-29848 )
SplitEdge: Makes a bad object (RH-38108 )
Toolbar:
brian
(Brian Gillespie)
March 22, 2017, 4:28pm
18
Rhino WIP 2017-Mar-21 is now available.
This WIP includes:
Bug Fixes:
Annotation:
Length units Prefix, Suffix don’t save properly (RH-38411 )
Missing scriptable -DocumentProperties page for Annotation Styles (RH-36979 )
_DimCurveLength does not respect the number of decimal places (RH-37639 )
Annotation: DimAngular: Make it possible to choose big or little angle for DimAngle when snapping to a definition point (RH-38285 )
Annotation: DimLinear: Dim command makes Rhino not responding (RH-38487 )
Annotation: Styles:
Breaks History (RH-38225 )
Editing annotation styles makes Rhino stop responding (RH-38492 )
Annotation: Text:
Document text keys & backslash (RH-38264 )
Text fields don’t autoupdate in a block in V6 (RH-37388 )
rich text font changes aren’t applied (RH-38510 )
BooleanDifference: Failure (RH-38416 )
CopyToClipboard: Long copy/paste (RH-38444 )
Cycles:
Changing Focal Blur can forget there was a background environment. (RH-38410 )
Fix RhinoCycles_SetRenderOptions to work better (RH-38176 )
Ground plane toggling doesn’t trigger re-render with correct gp (RH-38158 )
Make “Test” commands real test commands (RH-38478 )
Paint shader in Cycles does not act correctly (RH-38199 )
Raytraced mode doesn’t work at all and Rhino must be force quit (RH-38477 )
Using a 3Dconnexion device hangs Raytraced (RH-38336 )
DPI Aware:
Python Editor, Icons on menus not in correct size (RH-33578 )
Python Editor, toolbar buttons too small (RH-33579 )
Display:
Black artifact and poor shadows nvidia gtx 550 ti (RH-37650 )
Environment data slows down start-up (RH-38145 )
Ghosting on certain display modes when using GH (RH-36217 )
Ground plane incorrectly uses material (RH-38357 )
Modes not working (RH-38398 )
Pipeline does not respect the hidden property of a point in a pointcloud (RH-38248 )
Raytraced mode status bar can not display Chinese (RH-35714 )
Rendered viewport black after opening model (RH-34786 )
Display: OpenGL 3.3: Implement Bilateral blur shader for OpenGL 3.3 core profile (RH-37545 )
File IO:
IGES export (or import) issue truncating the name (RH-38032 )
STEP import crash (RH-38434 )
STEP import needs indicate bad object creation (RH-38219 )
V6 Picture material cannot be edited in V5 (RH-37508 )
Insert:
Gray out options for non-3DM files (RH-10178 )
Remember the last used block (RH-37899 )
Mirror: Mirrored Text is flipped (RH-29350 )
No Subsystem: Snapshots - Export selected/copy paste not working (RH-38347 )
OpenNURBS: ON_Font::GetRunBounds is inaccurate (RH-37906 )
Print: New PDF exporter - Print width of Details is not printed correctly (RH-37972 )
Properties: Typing in Dimension properties flashes (RH-38033 )
QuadMesh: QuadMesher fails to build in a clean debug x64 build because boost is not properly built (RH-38060 )
RDK:
:SimulatedMaterial can’t handle user-data preservation cases (RH-38470 )
Custom Viewport property page icon/title doesn’t show in Viewport properties page (RH-38369 )
Custom render mesh rendering not showing up in Raytraced (RH-38164 )
Geometry doesn’t affect the automatic ground plane position (RH-38413 )
Getting RDK render crc is slow, especially when excluding some parameters (RH-38368 )
Make “Test” command real test command (RH-38479 )
Override Cycles Settings is default page (RH-38438 )
Raytraced mode OpenGL Shadow settings don’t work (RH-38441 )
Sub-object material assignment doesn’t update unless reapplied (RH-34922 )
Rendering: Decal color and finish incorrect (RH-38280 )
Rendering: Materials: Icons for plastic bump texture types missing (RH-38143 )
Rendering: Realtime SDK: HUD Text disappears when creating a clipping plane (RH-38276 )
SDK: GHPython:
GhPython: Access component code when disabled (RH-38286 )
The TransformObject function does not accept Breps (RH-38298 )
SDK: Python:
A bug in AddRevSrf? (RH-31805 )
AddPlanarMesh not deleting input (RH-31557 )
The Python editor Variables output windows looks poor at High DPI. (RH-38303 )
SDK: RhinoCommon:
Need an Attributes UserStrings Clear method (RH-38317 )
Switching material editor layout to list or tree triggers assert in RdkQuickReasonToCommonReason (RH-38370 )
SDK: RhinoScript: Update RhinoScript API docs (RH-38422 )
Startup Template Dialog: Startup Template dialog shows English template files in Korean Rhino (RH-38151 )
TextObject: Command fails (RH-38377 )
ViewCaptureToFile:
Add missing bitmap file types (RH-34541 )
PNG has issues when opened in Photoshop CC (RH-34545 )
WireCut: Line created on the fly is sometime left when the command fails (RH-37789 )
Zoo: CloudZoo Client:
Error about switching license from Cloud Zoo to local Zoo (RH-38232 )
Login command should be renamed (RH-38456 )
What does not logged in mean? - Serengeti - McNeel Forum (RH-36986 )
brian
(Brian Gillespie)
March 29, 2017, 12:25am
20
Rhino WIP 2017-Mar-28 is now available.
Cosmetics:
Make2D: Dialog has excessive blank space at the bottom (RH-38289 )
Bug Fixes:
Annotation:
Dimension display text in prop. panel is “” instead of “<>” (RH-38553 )
Don’t warn on deletion of dimension (RH-38439 )
Make text format changes apply to entire strings when no text is partially selected (RH-37883 )
Annotation: Text:
Text font not shown correctly in edit or properties (RH-37978 )
BlendSrf: Don’t add all the interior edit point handles to start with (RH-38538 )
Cycles:
Alpha transparency does not work in Cycles (RH-38508 )
Custom Material not working properly. (RH-37339 )
Fresnel reflections not working in custom material (RH-38512 )
Full transparency + reflectivity with fresnel not handled correctly in custom shader (RH-38506 )
Reflection doesn’t work with diffuse texture (RH-38507 )
With cylindrical mapping (RH-38300 )
Detail: Layout Detail - Objects not visible til selection (RH-38604 )
Displacement: Default mesh memory limit could use to be higher (RH-38513 )
Display:
Anti-Aliasing no longer works in the display as of this morning (RH-38551 )
Any amount of reflection polish causes Rendered mode to display metal materials as solid black (RH-38255 )
Artistic display mode makes blank white viewport (RH-38261 )
Color in rendered viewport (RH-38497 )
Display glitch - Pick viewport border in non-default 4 viewport layout (RH-38544 )
Drawing messed up in Details w/Shadows (RH-35038 )
Glass is blue but shouldn’t be (RH-38237 )
Ground plane horizon line in view if Technical mode has shadows enabled (RH-38127 )
Mirrored blocks display flipped (RH-38129 )
Performance issue when drawing an object with custom primitive mapping (RH-38349 )
Rendered display wrong (RH-38099 )
Technical display issue if shade objects is on (RH-38126 )
Technical mode issues in Layout details (RH-34930 )
Arctic mode does not produce the correct results in Core Profile (RH-38097 )
Materials are getting “lost” when multiple light sources are used in Core Profile (RH-38100 )
The “blurring” of shadow maps isn’t working in Core Profile (RH-38110 )
Extend: Stopping extension (RH-38567 )
ExtractSrf: Failure in attached file (RH-38580 )
ExtrudeCrv: Misses shallow angle (RH-38321 )
File IO:
History: Incorrect break warning when deleting (RH-38511 )
Insert: Block Definition Properties dialog name incorrect (RH-37793 )
Layer: Drag and drop support onto controls outside layer manager panel (RH-38570 )
Libraries: No working materials (RH-38491 )
Offset: Misses when end weights are not the same (RH-38415 )
Picture: Pictures in block only display in Rendered mode (RH-37819 )
Pull: Failure on line to mesh (RH-38082 )
Rendering: Materials: Bump types on the Plastic material should also be available on metal (RH-38494 )
SDK: GHPython: GhPython. ESC key is disregarded in scriptcontext.escape_test() (RH-38555 )
SDK: Python:
RhinoPython Editor Method tree needs Function Groups (RH-37228 )
rs.SimplifyCurve(cvr, flags). Values other than 0 for flags result in unsupported operand type error (RH-31854 )
SDK: RhinoCommon:
Snapshot:
Snapshots - Render Settings Color adjustment client (RH-38549 )
Snapshots - Render Settings Wireframe client (RH-38550 )
SubCrv:
Subobject Selection: Make work on a single surface (RH-38519 )
TextObject: Make it work with accented letters used in many European languages. (RH-38484 )
UI Cleanup: Update Python editor icon images (RH-38320 )
ViewCaptureToFile: Transparent capture saves the grid (RH-38115 )
Zoo: CloudZoo Client: Logout and login won’t unlock file saving (RH-37106 )
Feature:
brian
(Brian Gillespie)
April 4, 2017, 10:38pm
21
Rhino WIP 2017-Apr-4 is now available.
Bug Fixes:
Annotation:
Baseline Spacing Value setting added to styles (RH-12314 )
Model space annotations scale incorrectly (RH-38630 )
Saving Annotation Edits Is Broken (RH-38722 )
Wrap leader text (RH-30943 )
Annotation: Leader: Curve width setting in display modes changes the width of Leader arrows (RH-38683 )
Annotation: Styles: Make annotation scaling separately controllable for Model Space and Layout Space. (RH-38643 )
Annotation: Text: Control for Annotation Scaling (RH-35246 )
Block: Annoying Question but no “Extra block” (RH-38355 )
Cycles:
DPI Aware: Osnap checkbox missing a pixel in 300% (RH-32731 )
Display:
Background turns red when rotating the view (RH-38689 )
Choose One Object menu does not highlight detail objects (RH-38428 )
Dot display is messy (RH-38403 )
Poor mesh edge highlight display (RH-37293 )
Shadows are incorrect when displaying nested blocks of objects (RH-38646 )
Startup display incorrect (RH-38220 )
Text Dots In blocks do not get clipped by clipping planes (RH-38530 )
Text in dots gets partially clipped when it should not be clipped at all. (RH-38528 )
Wireframe display on Mac not working properly (RH-37614 )
Explode: Incorrectly creates new blocks (RH-36985 )
File IO:
AutoCAD Import of 3DM - Text Not Visible (RH-38340 )
DWG/DXF: Support new annotation objects (RH-34323 )
SVG import needs to pay attention to font-style and text-decoration (RH-38585 )
GetPoint: Preview typed numbers and points when getting a point (RH-37187 )
Help: “Help topic not found” page is always in English. (RH-35019 )
Insert: no type default (RH-38581 )
Localization:
Japanese - ExtractMeshFacesByAspectRatio dialog needs more width (RH-38609 )
Japanese - ExtractMeshFacesByDraftAngle dialog needs more width (RH-38611 )
Korean Osnap Toolbar needs adjustment (RH-36272 )
Make2D: Missing lines (RH-38461 )
Mesh: Mesh preview is stuck at the first settings (RH-38543 )
MeshRepair:
Picture: bmp images won’t load (RH-38651 )
PluginManager: Plug-ins that do not ship with Rhino list is wrong (RH-38620 )
SDK:
CRhinoUiToolBarManager is obsolete (RH-38529 )
Crash iterating light table after worksession detach (RH-38622 )
SDK: RhinoCommon: Create a central place for Rhino.UI shared settings (RH-38714 )
SDK: RhinoScript: SelectLayer bool fails (RH-38719 )
TextObject: Command fails on recycling symbol and Asian language glyphs (RH-38183 )
Tutorials: All links in help menu of Rhino 6 CN version are inaccessible (RH-38589 )
UDT: Taper makes curved sides (RH-38673 )
UI Cleanup:
Custom .NET object property page Icon disappears (RH-38696 )
NumericUpDownWithText overlapping controls (RH-37756 )
Enhancement:
brian
(Brian Gillespie)
April 11, 2017, 9:58pm
22
Rhino WIP 2017-Apr-11 is now available.
Bug Fixes:
Annotation:
Changing annotations incorrectly changes all other annotations (RH-38725 )
Does not keep edits (RH-38723 )
Mask Color eyedropper multiple undo records (RH-38652 )
Overrides not saved (RH-38724 )
Prefix, suffix and undo records (RH-38641 )
Undo for numeric fields (RH-37641 )
Annotation: Hatch:
With History requires top plane (RH-38738 )
Annotation: Leader:
Control points ineffective (RH-38743 )
Delete curve point on leader object not working (RH-38739 )
Annotation: Text:
Investigate DirectWrite font substitution (RH-38534 )
RTF text area SelectionUnderlined incorrectly set to false (RH-38708 )
Bend: Copy morphing objects in attached models (RH-38786 )
BooleanDifference: DeleteInput option and attached models (RH-38634 )
ClippingPlane: Fills are not displayed (RH-34713 )
Convert: OutputLayer=Input option in commands like Convert in attached models (RH-38600 )
CurveBoolean: Failure (RH-38744 )
Cycles: Add UI for changing the new “throttle” value in Raytraced mode (RH-38446 )
DPI Aware: Python Editor, Breakpoint bullet is not DPI aware (RH-33575 )
Display:
Cache shader binaries (RH-38335 )
Display incorrect on block instance material (RH-37939 )
Shading colors wrong (RH-38455 )
Display: OpenGL 3.3: Black viewports on Mac Intel HD 3000 (RH-38671 )
File IO:
Command line parsing broken (RH-5802 )
DWG Chinese support is broken (RH-38721 )
EPS file does not open (RH-38542 )
RescueBlockOrphans (RH-38582 )
Rhino hangs exporting this file to dwg, solids scheme (RH-38496 )
Switch to Xfinium.PDF Toolkit (RH-38642 )
Grasshopper:
Material component needs to support RDK materials (RH-38597 )
Preview component should support output to custom render meshes (RH-38596 )
Gumball:
Add ability to extrude a point (RH-38579 )
Clear Gumball click defaults by entering zero (RH-38754 )
History: Squashes hatches on update if they are not on XY CPlane (RH-38726 )
Installer:
Add WIP and Release icons (RH-38824 )
Develop Rhino 6 Release and WIP icons (RH-34261 )
LayerStateManager: Material changes not saved/restored in layer manager state (RH-38435 )
OpenNURBS:
Errors with writing and reading RDK data. (RH-38700 )
Include freetype in public opennurbs. (RH-38812 )
PointDeviation: Start button not always visible (RH-38740 )
RDK:
C# DataSource provider Ids / content array implementations are incorrect (RH-38546 )
Render settings are not saved to the file (RH-38735 )
RenderMaterial doesn’t work properly (RH-38731 )
TestCustomMeshProvider crashes with Visual Studio 2017 (RH-38678 )
Rendering: Materials: Rendered Display showing model as black (RH-38770 )
SDK: Python:
Editor help links need help (RH-38318 )
The rs.ExplodeText function reports it is not implemented (RH-38246 )
SDK: RhinoCommon:
Allow for a panel to be shown inside a docking container without gaining focus (RH-38778 )
Allow for panel icon to be changed at runtime. (RH-38777 )
SDK: RhinoScript: Add rhinoscript.curve.AddTweenCurves(fromCurve, toCurve, steps) to RhinoScript (RH-38375 )
SetDocumentUserText: Does not appear to raise DocumentPropertiesChanged event. (RH-38800 )
Splash and About:
Disappears too quickly (RH-38749 )
Splash takes 40 seconds to find license (RH-38807 )
SubD: Remove SubD commands from Rhino 6 commercial version. Keep in WIP (RH-38669 )
UI Cleanup:
Add Rhino User Text plugin to Rhino solution (RH-38664 )
Convert ETO buttons to Icon toolbar in User Text panels (RH-38704 )
ViewCaptureToClipboard: Dialog preview image is blank for Technical mode captures (RH-38753 )
Feature:
Cycles: Render options should persist (RH-30374 )
Grasshopper: Add option to have Grasshopper push custom render mesh, but not draw it (RH-38448 )
SDK: RhinoCommon: Wrap mesh edge accessor in RhinoCommon. (RH-38586 )
Snapshot: Add material assignments (RH-38307 )
UI Cleanup: DocumentText and new Panel for User Text Properties (RH-29613 )
More Details…
brian
(Brian Gillespie)
Split this topic
April 17, 2017, 8:00pm
23
A post was split to a new topic: Viewport Properties Broken
brian
(Brian Gillespie)
April 19, 2017, 12:13am
24
Rhino WIP 2017-Apr-18 is now available.
Download Now .
Bug:
4View: Crash on 4View (RH-38873 )
Annotation:
Constant or fixed extension line (RH-14337 )
Copying “Objects and Dimensions” not working (RH-38695 )
Ordinate dimensions from V5 files come into V6 with the text in the wrong location (RH-38821 )
Set LockChildren On when making Dimensions - (was History and Dimension Oddness) (RH-37199 )
Annotation: Styles: annotation style ‘Apply’ button does’t work right (RH-38716 )
ChangeSpace: Does not work with new V6 Annotations Text (RH-37857 )
Cycles:
Colors render too light (RH-38658 )
Fresnel reflection affects diffuse when there is no reflection (RH-38830 )
Raytraced settings named incorrectly (RH-38846 )
Texture details lost (RH-38861 )
DPI Aware: Tear toolbar title bar not high-dpi aware (RH-38822 )
Display:
Cull wireframes/edges in viewport (RH-35314 )
Looks wonky when creating a new document in Mac Rhino (RH-38838 )
Rendered display has no object shadowing if a color texture is used in material (RH-38850 )
Rendered display mode produces incomplete image (RH-38827 )
Gets exactly one OpenGL error when drawing dots (RH-38527 )
macOS viewport drawing gets OpenGL errors when setting up a viewport (RH-38768 )
DocumentProperties: Some changes don’t turn on Apply button (RH-38834 )
ExportOptions: Wish to disable STL export warning message (RH-38922 )
File IO:
Crash when opening files fixed.
Incorrectly always shows a dialog (RH-29382 )
Installer:
Cycles plug-in not copying data to correct place. (RH-38832 )
Rhino Logo missing in installer (RH-38828 )
No Subsystem:
DWG/DXF Crashes WIP (with Cycles loaded) (RH-38877 )
No thumbnail in splash screen with raytraced viewport active (RH-38890 )
Offset: Cap does not draw dynamically (RH-38826 )
OpenNURBS: Add ON_2iPoint, ON_2iVector, ON_2iSize, ON_2iRect, ON_2iBoundingBox to opennurbs (RH-38844 )
Options:
Clicks make display mode tree node highlight darker (RH-38647 )
Hide useless settings for Raytraced from Options > View > Display Modes > Raytraced (RH-37927 )
PointCloud: No highlight on removed points (RH-38765 )
Print: Blocked Text moves in print (RH-38805 )
Project: Loose option wackiness (RH-38892 )
Buttons are clipped in the Material Editor bitmap viewer dialog (RH-38882 )
Material by parent - Object needs two Delete keys to delete (RH-37821 )
SDK: RhinoCommon:
Expose RhinoSmoothMesh C++ SDK function to RhinoCommon (RH-38462 )
Rhino crashes on startup when loading .NET object properties page (RH-38837 )
Snapshot:
Hangs on paste with many Named Positions (RH-38825 )
Typos in Snapshot (RH-38675 )
UntrimHoles: Add the ability to filter holes by size (RH-38568 )
Viewports: Crashes the WIP (RH-38886 )
Zoo: CloudZoo Client: Not able to switch Rhino account #1 (RH-37083 )
More Details…
brian
(Brian Gillespie)
April 20, 2017, 9:51pm
25
WIP 2017-04-18 has been removed due to a few bugs related to SaveAs and Export failing to overwrite existing files:
RH-38808 Rhino for Windows WIP does not warn before saving over existing file
RH-39011 SaveAs fails to overwrite file
RH-39004 Export Selected doesn’t overwrite an existing file
We hope to have a fix for this in the next 24 hours.
brian
(Brian Gillespie)
April 21, 2017, 4:13pm
26
Rhino WIP 2017-Apr-20 is now available.
Download Now .
Bugs Fixed:
brian
(Brian Gillespie)
April 26, 2017, 6:44pm
27
Rhino WIP 2017-Apr-26 is now available.
Download Now .
Enhancements:
New Features:
Annotation: Styles: Force dimensions arrows inside, text outside and underlined (RH-21176 )
Grasshopper: Add Rhino6 only load folder for Grasshopper. (RH-38222 )
Bugs Fixed:
Annotation:
“Edit Style” missing from panel (RH-38694 )
Add Force Arrows and Force Text controls to Linear and Angular dimension properties (RH-38806 )
Setting Linear Resolution doesn’t work quite right (RH-38991 )
Annotation: DimAngular: Dimensions incorrectly only consider model space geometry (RH-38517 )
Annotation: Text:
Multiline text import from V5 with hard returns does not wrap correctly (RH-38720 )
RText - Dialogs cannot show underlines (RH-34614 )
Remove ability to set Italics and Underline on the text of an annotation style (RH-38989 )
Area: Report tune up needed (RH-38947 )
ClippingPlane: Don’t work in technical modes (RH-38663 )
CurveThroughPolyline: Closed curve start-end location in CurveThroughPolyline when CurveType=ControlPoint (RH-38978 )
Cycles:
Add a way to reset settings to defaults (RH-38981 )
Changing max sample count in HUD doesn’t change all the way to the engine (RH-38987 )
Hide viewport properties page when active view is not in Raytraced mode. (RH-38759 )
Shadow Only ground-plane is broken (RH-39037 )
Viewport lock not working properly (RH-38962 )
DPI Aware:
RhinoScript Editor, triangles on buttons are clipped (RH-33515 )
The controls in SetPt dialog are too close at high DPI display settings (RH-39027 )
Dir: Flip does not update display (RH-39007 )
Display:
Black objects in Rendered Mode when rotating (RH-38903 )
Disabling skylight causes OpenGL error and results in black viewport (RH-39003 )
DivideAlongCreases: Area estimate incorrect (RH-38853 )
EditScript: The default input language for RhinoScript Editor should be English (Narrow). (RH-26037 )
Export: Export Selected doesn’t overwrite an existing file (RH-39004 )
File IO:
Rhino for Windows WIP does not warn before saving over existing file (RH-38808 )
Rhino misses a polycurve (RH-38848 )
SaveAs fails to overwrite file (RH-39011 )
FilletEdge: Edit option in Fillet/Chamfer/Blend Edge missing in Rhino 6 commercial build (RH-38982 )
Help: Documentation on Annotation Style Panel -> Right Click Menu (RH-38717 )
Layout: Layout window always appears (even when closed in previous session) when opening files that contain layouts (RH-36527 )
PluginWizards: Create new RhinoCommon wizard for VS2015 and VS2017 (RH-39065 )
RDK:
Automatic UI needs rewriting from scratch (RH-35395 )
Panel buttons broken (RH-39021 )
SDK: RhinoCommon:
Review V6 SDK Cleanup Document (RH-38932 )
Sweep1:
Move m_bSimpleSweep and TestForSimpleSweep() from CRhArgsSweep1 to CRhinoArgsSweep1 (RH-38975 )
There is no preview of the surface (RH-38715 )
TweenSurfaces: Tween workflow (RH-38927 )
More Details
Download Now and report any problems in this forum.strong text
brian
(Brian Gillespie)
May 2, 2017, 11:12pm
28
Rhino WIP 2017-May-2 is now available.
Download Now .
New Feature:
Cycles: Allow selection of multiple render devices (multi device) (RH-37680 )
Bug Fixes:
Annotation:
Annotation: DimLinear: Baseline, diameter, and radius dimensions not moving (RH-39113 )
BlendSrf: Add an option to turn off simple blends (RH-38835 )
Cycles:
Crash switching from Cycles to Wireframe (RH-39017 )
Linear Light mesh in Cycles seems to be bad (RH-38858 )
Linear light doesn’t react to On toggle in light properties panel. (RH-39031 )
Linear light problem (RH-38856 )
Linear light vanishes when Cast Shadows is toggled (on object) (RH-38857 )
Raytraced viewport black (RH-38751 )
Texture shows through on GP with shadows-only enabled. (RH-38730 )
DPI Aware: Value box in Gumball is not DPI aware (RH-39050 )
Decal Planar, Spherical, Cylindrical, UV: Decals mapped in reverse (RH-38699 )
DeleteHole: Support command line input in of MaxLength (RH-39089 )
Display: OpenGL 3.3: Ground plane reflections don’t work in core profile (GL33) (RH-38095 )
Eto: Add “tab stop” functionality to Eto (RH-38790 )
Export: Not exporting arrow type (RH-38878 )
File IO:
AI Export Dialog has truncated control labels (RH-39092 )
Crashes Rhino WIP on double click to open (RH-39049 )
PDF Import plug-in is labeled PDF Export (RH-39095 )
Grasshopper:
Grasshopper MRU server using lots of memory. (RH-38813 )
Grasshopper delivery of Custom Render Meshes is very primitive (RH-38595 )
Handle zero area regions. (RH-38988 )
Transform is not viewed correctly (RH-38297 )
Length: SubCrv and Length command (RH-38819 )
Localization:
Some command prompts in Trim command in English (RH-39122 )
Make2D: Incorrectly makes zero-length lines (RH-37841 )
Properties: Edit Style button does not work if overrides are present (RH-39045 )
Rendering: Materials: Materials - Suggestions for Material Editor tags (RH-33687 )
Rendering: Realtime SDK: Lights don’t react to Cast Shadow toggle in object properties (RH-39030 )
RotateView: Allow Ctrl-Shift RMB to override “Always pan Parallel views” set in Options->View (RH-39009 )
SDK: Python: The function coerceplane() should take 4 arguments (RH-38485 )
SplitEdge: Distance from last point (RH-38879 )
TweenSurfaces: TweenSurfaces fails (RH-38928 )
Viewports: Not able to manipulate the viewports (RH-39123 )
More Details
