The new update crashes each time I open R9 WIP. These files were created in R9 so I don’t get why they don’t open. This is an emergency.
Did you try uninstalling and reinstalling?
Does opening Rhino in Safe Mode help?
I did not. I will try.
Thanks
Can you start Rhino and get an empty file by clicking the “New” button on the splash screen?
Please send me one of your files that is crashing. I made some optimizations this week that may be related to this bug. If I can repeat the crash, we’ll get a fix in place right away.
I can but I need the upload address because the file is big.
Thanks
I received your files Joe. Thanks. I’ll try digging into this right away
@Joe_Neill I’m able to repeat the crash and am working on a fix. I’ll let you know when a fix is available
Thank you.
I have a fix in place and will send you an updated WIP once one becomes available which usually takes several hours.
Bravo, thanks. What was the problem?
One of the images in the file was not properly being read by Rhino. The older code just silently failed when this happened and now the newer code is obviously just crashing Rhino. I’ll send you a link to a new build in a private message.
Hi Brian G.
I didn’t see that fix on the list of updates. However, the problem i had and was given the ID RH-90458 was not on the list either. Are they the same?
Thanks for keeping me in the loop.
Joe
Hello again Steve,
I installed the new update today and I am having a similar problem as with the last update. I cannot open my drawing. It is not the same drawing that I sent you before and it is a bigger file, R9 tried for almost 8 minutes then crashed.
Best
Joe
Darn, sorry about that Joe. I had to make a last minute change to revert some of the functionality I added for this because what I added ended up breaking functionality with regards to pasting screenshots into Rhino on Mac. I’ll start looking at this again with your model to try and get this fixed as soon as possible.
Thanks Steve, I have forgotten which file I sent, so if you need another I can send it but it is a rather big file.
Joe
I was able to load the file that you previously sent in the WIP, so I may need another upload from you to make sure I’m testing against the right file.
OK. The only consideration is that the that wouldn’t open is bigger.
Helllo, Brian G.,
That fix was not my problem. Between actions R9 takes forever to permit another action.
Joe
