New random seed for every branch with nodes
Attached -I need to create a random number that is different for every branch. Not sure how to have a seed change for each branch and not repeat as you can see in the attached screenshot.
this will generate N random integer numbers in range A for each branch in B
make sure to input a high enough max-seed value in C
[edit] and of course the only seed you play with (to refresh values) is this:
Instead of changing seed for every branch:
random.gh (7.7 KB)
Oh gotcha, I understand now. Thank you so much.
