New problem with tool bar
Hi!
Sorry, i have a new problem again with the tool bar: as you can see here on my screenshot, at the left, i can’t have all the tools, for example, now, i don’t have the tool “transformrm”, it’s hidden, an this is not the default tool bar.
The big problem is even if i do “_toolbarreset”, the problem stays.
Other big problem, is that, as you see at the bottom, now, the “accrochages” does not appear: for example, if i want that my drawing is snaping with a point, i don’t have the option to see all the logo picture that should appear: point, extremité, milieu…
For me, all this is a big problem.
Can you please help me?
Thanks so much! :disappointed_relieved:
It looks like there is another toolbar below the Main toolbar that makes the main toolbar not show all of the buttons:
If you drag the lower toolbar onto the viewport, that should probably give the main toolbar enough space to show all buttons.
What happens if you click on this Accrochages field? That should make the toolbox appear.
Alternatively, you can run the _ShowOsnap command to make the control visible.
Hi Wim!
Thanks so much!
Well, even if i click on Accrochages field, it does not appear, but, i drag the lower tool bar on viewport, and now, it’s ok ! Thanks so much! :slight_smile:
