@menno The new version of Patch appears to require at least one edge constraint. Is this intended? If so I consider it a regression from the old Patch which did not required any edge curves, and in fact will create a surface from only a group of points or a point cloud.
I sometimes use Patch with a set of internal inputs, which may be curves or points created from a scan data. There may not be any “edges” available. The resulting surface is used to visualize the shape and look for any points or curves which appear to be out of position.
