New material goes to bottom of list
Hi there,
I’m wondering if it’s possible for Rhino to create new or duplicate materials directly under the currently selected material?
Current behaviour shown in video
I couldn’t reproduce your issue. please share your system info, also does this behaviour applies to this file only? or is it happening universally?
Hi Tay,
I just replicated the issue using a blank template in feet; a template I never use (metric).
Rhino 7 SR25 2022-11-22 (Rhino 7, 7.25.22326.19001, Git hash:master @ 2a680490f96a04550d1f39158b859c4f7739d024)
License type: Educational, build 2022-11-22
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 11-8-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 526.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-8-2022
Driver Version: 31.0.15.2686
Z-Buffer depth: 24 bits
Total Video Memory: 10 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.25.22326.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.25.22326.19001
You are 2 updates behind. Can you update your rhino and let me know?
actually, I was able to get the same behavior when in List View mode. I think it should be sorted automatically, otherwise use the “Sort Alphabetically” toggle below:
Updated, and the behaviour still persists no matter which view mode is used. Duplicates are always sent to the bottom. Also, the sort alphabetically button is not a persistent one… you need to keep pressing it after you make a new material
Cheers,
Jeremy
@wim @BrianJ
Can you look into this issue? I don’t think it works as intended, also I don’t see this issue in Rhino 8 but it seems that there is a bug in rhino 7.
Hi @tay.othman and @jdelavaulx Apologies for the delay in looking into this issue. I located the fix that prevents this issue from occurring in the Rhino 8 WIP (RH-71587). I’ve asked the developers if it is possible to push this fix to the next service release of Rhino 7 as well.
