brian
(Brian Gillespie)
1
Rhino WIP 2017-Aug-29 is now available. Download Now.
New in this release:
New Features:
- SDK: Python: rs.CompareGeometry wish (RH-25085)
Bug Fixes:
- Block: Modifying a nested block reference incorrectly changes inserts to top level blocks (RH-40996)
- Cycles:
- Diffuse alpha does not work correctly in rendered display (RH-40164)
- Raytraced viewport artifact when scaled to millimeters (RH-40378)
- Display:
- Changing solid color backdrop doesn’t affect look of objects even though skylight is enabled. (RH-41084)
- Dropping lines and appears jagged (RH-40743)
- Render display mode not showing materials correctly (RH-41005)
- Grasshopper:
- ExplicitHistoryDeveloperSettings Dialog causes crashes (RH-36554)
- ExplicitHistoryDeveloperSettings dialog does not accept directory paths when browsing (RH-36559)
- Insert: Dialog incorrectly prompts for block filename on command line (RH-40995)
- No Subsystem:
- Component profiler display in GH ( RHINO WIP) (RH-40884)
- :TimerStart() (RH-41120)
- Rhino crashes hard in the RDK when changing the Render setting for background color (RH-41130)
- Panels: Add the current location (RH-38606)
- Properties: Viewport properties flickering (RH-40607)
- RDK:
- GUI redraw messed up in material section (RH-39124)
- GUI redraw messed up in material section (RH-41061)
- Rendering: Materials: Update library textures (RH-40286)
- SDK:
- RunScript has a initial document context - so a document should be passed in. (RH-39533)
- Update WIP DevDocs for Visual Studio 2017 (RH-38466)
- TextObject: Bold and Italic hard to cancel in TextObject (RH-40150)
- UVEditor: Does not display wcs projected textures correctly (RH-35013)
More Details.
Download Now and report any problems in this forum.
