New in Rhino WIP 2017-Oct-31
Rhino WIP, Halloween Surprise, is now available. Download Now.
New in this release:
Task:
  • Grasshopper: Update Kangaroo 2 to 2.4.2 (RH-42173)
Crash:
  • SDK: RhinoCommon: UNKNOWN!Rhino.Runtime.CommonObject.ConstPointer – (NTSTATUS) 0xe0434352 - (RH-41730)
  • Unweld: Vertices crash (RH-42110)
Bug Fixes:
  • Annotation:
    • Style dialog does not refresh (RH-42236)
    • Style option in Dim collides with S to turn on/off Snapping (RH-42136)
  • Annotation: DimAngular: Lockup placing DimAngle (RH-42163)
  • Annotation: Styles:
    • Fraction stacking format: No Stack doesn’t work (RH-42135)
    • Updating dimension style font fails (RH-42140)
  • Annotation: Text:
    • Font buttons not being applied when multiple annotation text objects are selected (RH-42150)
    • Text edit control shouldn’t lose focus when font drop down control is accessed (RH-42143)
  • Build Process:
    • Add target branch to commit status context (RH-42176)
    • Block merging of master into 6.x and release-6.* branches (RH-41701)
  • ClippingPlane: Dynamic feedback on clipping planes is chopped (RH-42011)
  • Cycles:
    • Calls IRhRdkRenderWindow::SetSize when drawing with OpenGL (RH-42186)
    • Linear light crashes Raytraced (RH-42187)
    • Raytraced too white (RH-42061)
    • Rotating HDRi environment doesn’t rotate reflection component (RH-42183)
  • Display:
    • Commit introduces OpenGL error and regression test failure. (RH-42115)
    • Drawing freezes after saving (RH-40115)
    • Rendered mode completely broken in VMWare 10 (RH-42051)
    • ViewCapture + Transparent background doesn’t show fresnel reflections (RH-42231)
    • doesn’t work in Wireframe (RH-42180)
  • ExtendSrf: Change curve extend from Smooth to Natural (RH-41741)
  • ExtractConnectedmeshFaces: Cancel with no selection (RH-42043)
  • File IO:
    • Export and overwrite warning (RH-41919)
    • Open: AI – Text being combined (RH-32368)
  • Geometry Core: Generalize CFitHDCubicNurb to arbitrary degree (RH-42134)
  • Grasshopper: Components: Kangaroo2 doesn’t show up in Grasshopper for Rhino WIP (RH-42174)
  • Gumball: Autoreset on view or CPlane change (RH-42022)
  • Insert: Block instance Scale options are broken (RH-42087)
  • Installer:
    • Installer not localized in Polish (RH-41750)
    • Pangolin/Mesh2 not in WIP builds (RH-42171)
  • Localization:
    • Button Editor dialog needs some adjustment for Korean and Japanese (RH-41907)
    • Long strings gets truncated on Toolbar tabs on Japanese system (possibly in other languages, too?) (RH-41982)
  • Make2D:
  • OpenNURBS:
    • Create tool for automating testing of 3DM file conversion (RH-41835)
    • Create unit testing framework for 3DM I/O (RH-41999)
  • PointDeviation: Prompt tune up (RH-41515)
  • Print:
    • Print soft shadows from a detail doesn’t work (RH-42021)
    • Right-aligned leader prints wrong (RH-42138)
  • RDK:
    • Eto Lights tab is not Windows UI compliant ([RH-38426]
    • Option to disable “Missing image files” dialog box (RH-42104)
  • Rendering:
    • RenderBlowup command added (RH-4988)
    • Skylight shadows in Rendered mode produce a blocky artifact now (RH-42116)
  • Rendering: Materials: Icon missing from tools menu (RH-42130)
  • Rendering: Texture Mapping: Rhino hangs when changing texture mapping size on ground plane (RH-42209)
  • SDK:
    • :GetClosestPoint to public SDK (RH-42202)
    • Add RhMakeCompatibleNurbsSurfaces to public SDK (RH-42201)
    • Add RhinoMakeCompatibleNurbs to public SDK (RH-42200)
    • Expose Macro Library to SDK (RH-39596)
  • SDK: RhinoCommon:
    • Changing the Command window dock location in a Skin Plug-in does not work (RH-42198)
    • TextEntity has no FontIndex property (RH-42139)
  • Sweep1: Doesn’t work (RH-42060)
  • TextField: Help button not hooked up (RH-42124)
Download Now and report any problems in this forum.
