Yet most people will just use the default and be happy about it
I think an approach like the one you can see in the video below should be chosen.
Also, there should be custom options and these themes should also be able to be shared.
It’s Rhino 9 WIP’s vastly different direction to change the looks of the toolbar icons (washed-out colours, low-contrast outlines, replacing certain blue objects with lime green ones) that causes more issues now, so bringing this topic to where it’s now is the natural consequence of the drastic decisions introduced by “McNeel”. ![]()
Correct me if I’m wrong, but the unmatched customizability of icons was one of Rhino’s strengths for nearly two decades up until Rhino 7 (before axing the icon’s integrated paint tool in Rhino 8). I tried to draw some icons inside Rhino 8 and the available tools were hugely restricting, meaning I was forced to use an external graphics program to be able to customize the looks of the icons.
Even if I was not colour-blind, I would still say that the new low-contrast icons are very user-unfriendly. And that’s before taking into account the potential change of the background to something like RGB 190, 190, 190 that make the washed-out icons even more harsh to the eyes. ![]()
Since Rhino 8 and Rhino 9 use SVG format for the icons, the best solution is to let the users control the looks of the icons both individually and globally via several sliders for quick adjustments. I already mentioned that earlier in the topic. Make the outlines as a separate layer of the icons, so that it will be easier to control the contrast of the outlines of all icons in seconds. Do the same with another slider for the saturation (or up to 4 sliders if you put various objects of the icons inside different categories: main object 1, main object 2, main object 3 etc). The “Join” icon, for example, consists two primary colours (white and orange) plus a black outline. This means hat this particular icon would be easy to modify with just 3 sliders plus a colour box to pick the colours.
P.S. Taking the time to share personal opinion and bringing solutions is not hating. ![]()
OR
“Users suffer from the newly introduced changes to the UI and want a way to fix that. Or at least an option to use a legacy set of icons”
i completely understand, i definitely did not elaborate on that close enough and expressed that simply wrong. lowering the brightness contrast is not what i actually meant, but “contrast” indeed plays a role here, though differently which i will try to point out below.
yes of course, but not just the external surroundings but also the dark or bright setting of the Rhino UI background and of course all our eyes are different even the healthy ones perceive the same image differently in some or more subtle ways, more so when you have issues with the eyes under which conditions one should maybe not sit at the computer too much anyway
→ but what i mean here in specific is the chaotic mess which puts a strain on the brain much rather, too much “contrast” what i meant is when you add too many elements you clutter the space and the perception additionally. when there is a lot of bright white and too many intricate linings on a darker back ground is just like someone shines a torch into your face. its not just about the intensity but the lack of differentiation, or to make it more clear too much differentiation going on.
in specific when we look at this icon here below for instance, we have a dark background then a grey boarder then a black boarder followed by a big blob of white with black outlines for the sqares filled with white again making the white surface with too many isocurves just top off the entire thing into a chaotic goo completely. i believe most of it on the outside is added because someone did not want to bother making the icons respectively for each UI mode. AND why is that surface round anyway? round elements remind me of spheres, dots much more, surface? never ever.
when we switch the UI mode the icon becomes slightly simpler the grey boarder is missing but still is a total mess of too many elements not adding anything.
similar with many other of these icons.
other applications as also expressed here by some have 2 sets of icons. for Rhino we would need nothing more, one for monochrome and one for the colour, if the icons are prepared properly and the shades of grey are chosen smartly that a switch in UI dark, bright will not harm it and the double triple boarders avoided. add a slider for the intensity of the colour and we are done, no further sets needs.
This thread suggests to me that these are discussions that have been thoroughly examined over the decades that computer and television interfaces have existed by the professionals that design the interfaces. It sounds like the kind of thing you’d get when the cement contractor or plumber start discussing architecture.
The people who are good at interface design have put as much study and experience into it as the successful architects and product designers that use Rhino or the developers that create the functionality of Rhino have put into their expertise. I know because I have a son who has been doing it for decades and I know what he went through to gain his expertise.
Sadly, “it takes one to know one”, and I’m not sure that the McNeel folks, despite the fine qualities that make them our favorite people, really understand what a specialized field it is or how to find and select the person or team that will give them the outstanding UI they need and their users want. Not just appearance but ergonomics.
So we live with the product of UI amateurs doing the best they can as a necessary afterthought of making their core product more or less function. Kind of the “garage band” of UI design.
Reminds me of a thought that frequently occurs to me when I am at a symphony concert and I see this guy or gal standing on a platform waving his or her arms and think “that is sure easy - I could do that. And they get paid the big bucks, too.” Then I once again pay attention to the music that brings joy to my heart or tears to my eyes and the realization sinks in that its the result of the years of experience and talent for leadership of the hand-waver that produces the deeply satisfying musical experience. None of which would be possible without the individual contributions of the expert musicians that have just as much invested in their areas of specialization as the conductor. And when you’re standing behind one of them at the supermarket checkout they look just like anyone else and you’re completely unaware of the secret storehouse of expertise contained within them.
I guess multiple icons for the tools are the best sollution for how McNeel has solved this now.
Only read on if you have nothing better to do:
Getting a professional GUI done right is a huge job, time I would prefer to see McNeel spend on bug fixes and optimizing modelling tools. I am happy for all the enormous work they have put in, and all the shouting they have gotten from us because we see an even higher potential in their baby… But keep in mind that this is a software made by few and affordable by many, flexible like crazy and always supporting of their customers. (Point is: Hiring more people to do stuff like AutoThisAndThat does doesn’t help, that’s why we prefer using Rhino over SolidSomething or ArchiWhatnot) So let’s help them modifying stuff the right way. We have wished for a dark GUI for years, I was on the forefront on that wish back in Rhino 4 already since I spent so many hours in front of the monitor at night
and now we have got it, but not in a way that just works. Adding dark mode to vectorized icons wasn’t a good move when it was done like this. Native icons are visually noisy and as @encephalon says: “a strain on the brain” in dark mode. But my icons don’t handle dark mode anyway… The red was a bad color choice for that too.
I looked forward to updating our toolset to vectorized versions, but the iconeditor isn’t up for the job and can’t be used for anything. And I won’t spend time making an extra set of icons for my tools, so I will stick to light mode.
My impression is that the Standard tab, along with the side bar, is where it looks cluttered.
Because in there is a mixture of tool ‘groups’ - curves, srf, solids, transformations etc.
And now in different colors the mix becomes obvious.
The other tabs are more organized, not perfect, but no real need for color coding the tools.
Some of us are used to the Standard tab because the tabs came up with V5.
There is no need to use other tabs, nearly all works from the Standard tab.
I myself needed time to get used to the tabs.
The order of tabs is strange:
- Standard
- CPlane
- View
In the menu is a different order: - View
- Curve
- Srf
The order doesn’t match.
Radical idea:
a) Replace the Standard tab with a File tab and reorder the tabs more logical.
b) Reveal the contents of a tab by mouse hovering over the tab, so that one can click a button in the tab.
c) This tab will remain visible then.
d) Remove the left sidebar completely.
a) like this:
That is Nice! Should download V9 again.
Everyone has their own preferences, and even two people who share the same views will also have differences.
- I don’t like the new design of Rhino 9.
- A similar situation happened with the change in the design of the Sketchup program, where the strict icons in old versions began to look like a clown’s masquerade.
- The best thing I’ve seen from monochrome icons on a dark background is Photoshop (these icons also look great on a light background)! And I fully support encephalon, who spoke about icons without pronounced contrast!
- I like monochrome icons! For example, in Blender, I turned off all color design on all icon groups and it became a bit like the Photoshop interface
- The best solution for the Rhino 9 interface is to make it possible to change the color of each icon group (or turn off the color altogether), so that each user can customize the program to their taste.
Good luck to everyone!
Rhino icons are miniature pictures of objects. It seems that colors of the objects are random. I propose a few rules: points are red, lines are green, surfaces and polysurfaces are blue, SubDs are cyan, isocurves are yellow, meshes are magenta, imaginary lines are gray, solid edges and text are black, background is white. Original objects have light colors. Final objects have dark colors.
I proposed this idea in 2018: A complete UI overhaul of Rhino would be a much welcomed move - #45 by Andrew_Nowicki
Colors, at least in the original version of the new icons, are not chosen random. They followed a set of rules, but not the rules proposed by @andrew.nowicki
What are these rules? At best, they convey several times less information than my rules.
Colors in Rhino 7 are great, though a lighter shade of blue fits better with medium gray background (RGB 190, 190, 190).
There is no need to add extra colors and low contrast just to make the icon readability harder for color-blind people. Especially with red and green accents inside the icons.
Red points and green lines are bad for the eyes…
At the very least, can’t we just leave the traditional Rhino icon blue unchanged, instead of using that horrible “Smurf” blue?
Did this update already happen? I didn’t follow every WIP release, but as of now (June 26) the current icons combined with Dark Mode create a complete visual clash.
For Dark Mode, a few presets would also be very helpful, so users could quickly switch the viewport to a darker look without having to dig through tons of settings.
What do you think so far in 2026?
