From the perspective of a colour-blind person, I perceive the grey colour next to the light blue colour as the same colour, especially when one of them is too small. Example: The grey holes on both “Untrim” icons.
The icon for the “ShowEdges” tool is also extremely distracting, because it combines red and green at once. The combination of these two colours is highly distracting for the majority of colour-blind people who suffer from “red-green color blindness”. Graphic designers must be aware of that negative effect, along with similar other bad combinations, and should consider mixing various colours with the colour-blind people in mind (8% of the male population).
Also, what about the “Join”, “Split”, “Scale”, “Flow along surface” and other icons whose blue colour was replaced with lime green? That shade of green is also distracting for my eyes, especially in a combination with blue. I would much prefer fully blue icons instead of having lime green there…
Some icons lack a proper gradient. This is both distracting and makes it difficult to read certain elements. Example: The dotted line on the “Adjust closed surface seam” icon is difficult to notice, because it’s located near the sudden contrast between blue and while. A nice gradient there would make the dotted line much easier to notice and less distracting for the eyes.
The “Convert to single spans” icon has an unequal shape, which is also not optimal. The inner curves are too straight. They must follow the more pronounced S-shape of the border. That also applies to the inner curves of the white surface. Currently, the upper grey curves below the blue surface are too close to its dark blue outline. This is being perceived as a single thick line from a distance (again, from the perspective of a colour-blind person with reduced vision capabilities). Replacing the dark blue outline with black will reduce the negative effect.
For my taste, it is a subtle visual improvement. I like the more abstract gradient and some of the more subtle details. But that is a matter of taste. If we start a discussion about tased …
My question is: What is the overall approach? What makes a design future-proof?
We need a concept!
Again, we can learn a lot from here https://rhinoui.com/ because it is not just about taste—it addresses actual needs.
For example (rhinoUI):
„Color Coding System
Colors are used to differentiate the different buttons. Gray is the base color, which can be used for solid or functional buttons, blue represents surfaces, as well as differentiating colors, blue-green for SUBD functions, green for Mesh, yellow for lights, and red for edges or warning colors. (Colors are not finalized yet)“ - rhinoUI
But to the Rhino team—thank you for taking these approaches and having a discussion with us! It is definitely the right time and a step in the right direction.
The fix is pretty easy, but it depends whether the “McNeel” team wants to take into account colour-blind users:
Avoid low contrast icons with washed-out colours (Rhino V7 and V8 icons were nice, Rhino 9 WIP icons are bad);
Avoid combinations between red and green colours, or between light blue and lime green, or filling small holes in blue objects with grey as they look like the same colour for those with damaged vision;
Keep the saturated blue objects and don’t change them with lime green;
Keep the outlines solid black;
If necessary, create two separate sets of icons for the light theme and dark theme, but don’t use the same icons for both themes. These tend to work equally bad in either case. Nice saturated colours work best for the light theme, washed out colours work best for the dark theme.
The time and money invested into making these icons easier to distinguish by colour-blind people are negligible. In fact, currently “McNeel” spends more money and time to make the icons in Rhino 9 worse than what they were in Rhino 7 and Rhino 8. The latter were much easier for the eyes, especially the eyes of colour-blind people.
Also, I would not call 8% (1 out of 12) of potential users a small percentage.
One good thing in Rhino since years is the fact that the major colours are named with their respective name next to the box with the actual colour in the colour picker panel.
Only time will tell, personally I like to have all the options on the table and act accordingly can’t find the solution presented just create it yourself.
Some of the icons are not that bad for my eyes, but the ones with a combination between light blue and light green and red are “moving” when I look at them. I have both colour-blindness and astigmatism. I see much less colours than people with normal vision. For example, most of the time I may see orange, but in reality the true colour (according to my graphic program) is either lime green, orange, darker yellow or light red.
The same goes for many shades of red and green that I mistakenly see as another colour. I see pink and grey almost like the same colour, too. If red and green elements are touching together, I see a dark border between them, even though it’s non-existent. Other times the non-existent border may be white or yellow. This means that certain colour combinations create an effect of constantly switching bright or dark blinking outlines (like disco lights) that are distracting for my eyes.
I see those icons nicely only if I stare at them from 20-30 cm away. When I look at them from a normal distance (60-80 cm) during work, I see them blinking, especially if blue and red or green and red elements are used together.
Wow. It’s all about including an optional set of legacy icons with the same high-contrast graphics style as in Rhino 7 and Rhino 8. Most likely Rhino 8 icons are easier to add as an alternative to Rhino 9, because they are already in SVG format, so the options could look this way:
Light
Dark
Custom
Legacy V8
Hi @Rhino_Bulgaria et al
Fellow colourblind here - semi-severe deutan aka red/green colourblind - and I of course agree 100%, for my case especially on the washed out/muted colours. The green (transform) and aquamarine (or whatever it is for Sub-D) are hard for me to distinguish. Same goes for yellow (select) and orange (rendering). Colours are one of the main reasons I’ve accustomed myself to using aliases rather than icons over the years, so I hardly use any icons - actually only the tabs, and there it’s all muscle memory; I don’t look at the icons at all Since this is what I’ve grown accustomed to, it really doesn’t concern me much, but I can definitely confirm that the current WIP is hard on the eyes work-wise. Other than that, I actually really like the look and “feel” and I’m a big fan of getting rid of the white lines/curves - they are almost impossible for me to see.
-Jakob
I actually like the white lines inside the icons, but that’s probably because I set the toolbar background to RGB: 190, 190, 190.
I see replacing the white lines with black ones as a visual downgrade and more difficult to distinguish the elements inside the icons. But, as I mentioned, that’s because I use a slightly darker background than the default Rhino.
I like the idea of having selectable styles, perhaps combined with a style editor.
And if grey is preferred, it could look like this.
IMO this wouldn’t be too complicated in SVG rendering.
One idea, but I’m not sure how much work this would involve, would be to set the zoom of the icons, in a customized percentage, to the side or in the same position once the mouse hovers over the command icon.
highlighting the command with an outline as in this case in yellow, but with the possibility of being able to modify it as desired
im gona hard pass on this new update on the WIP did we go through barbies drawers now and found her toys? at this point ill stay with rhino 8 for another 10 years i refuse to humiliate and torture my eyes for hours like this.
PLEASE TELL ME THIS IS AN OUT OF SEASON APRIL FOOLS JOKE?
