I am seeing a lot of these driver crashes now with SR9 too.
System has been stable for more than a year and now the drivers crash a lot, at least when I am using Python script in a button.
Mitch’s crashes were incorrectly being identified as video driver crashes when the real problem was a crash in the .NET garbage collector on a different thread when attempting to clean up some of the work from a python script.
If you have a script that is frequently causing crashes, I would like to see it if possible,
In my case the screen flickers and Windows 7’s transparent startmenu turns blue. And I do not get any warning from the OS. Rhino does not crash most of the times, but I have to restart the machine to get the drivers to work properly again. No new drivers installed.
I’ll see if it happens next time I use the script.
I can’t repeat this here… I have had lots screen flicker and almost blackouts here, but it’s only when I am trying to run my video script which involves lots of screen redraws - I think I’m overloading some video buffer somewhere… But with a normal script, Rhino maxed on one monitor and python editor on the other (which I do all the time), running a script from a button runs totally normally.
