Hello - I do not know… I would try a Repair (Windows control panel > Programs > find Rhino 6, >Modify > Repair), on the installation first, and if that does not sort it, I’ll check with the developer.
I saw this happen awhile back - there must be a thread on it somewhere - but IIRC, it was on the Mac side?
Sorry no, I was confused, it was not quite the same thing…
I tried the repair with no difference, except all the tool menu check boxes became blank (options/tools) and any panels (layers, Named views) that I had open on a second monitor were closed. Not a problem just a nuisance.
I can select NEW from the file menu and select the presets to begin a new drawing.
MS
Hello - do the expected template files exist in your template folder? Default is
C:\Users\USER_NAME\AppData\Roaming\McNeel\Rhinoceros\6.0\Localization\en-US\Template Files
Template files exist there as expected. All dated 12-3-19. the date of the last update when this display first showed itself.
I can mouse down the blank display and the yellow box to the right will describe the template but only one shows on the left and is selectable.
Like I said, it’s not a special issue, just a weird display after the update.
MS
