A new parameter has been added to the ChangeQueue constructor:
bool bUseDisplayPipelineAttributes
Can you give us a hint about how to use it?
Carsten
It should be “true” if you are running in the viewport, and false if you’re running in the render window.
I see, thanks!
I just tried to set this flag to false for our Iray production render and Rhino crashes in rdk… Investigating.
What does bUseDisplayPipelineAttributes trigger please?
@nathanletwory, @andy, do you confirm this should work?
It means that changes to the display attributes (like custom materials, custom backgrounds, etc) will be passed through the change queue.
Can you give us a call stack for the crash?
