NetworkSrf bug? Simple 4 lines networking won't work
I draw three basic _curves (mirror to the other side), got four curves. Then tried to cover the whole area with NetworkSrf.
What NetworkSrf actually do? It cover just half.
I don’t know why NetworkSrf put B letter in the middle. Even If I draw from begining, the results are the same, if I draw lines with _curves.
I solve the problem in the middle of writing this post.
Warning for the users. If you draw lines and mirror to the other side, so that you got circle, NetworkSrf will not work correctly. It will not cover whole area with srf.
That’s I know for now :slight_smile:
Have a look at the Help article for NetworkSrf. It clearly describes and shows the requirements for the input curves.
Just start the command and hit F1
